| » leaking washer |
Model Number: mws445res1 Brand: White-Westinghouse Age: 5 - 10 years
My washer leaks from the bottom,it looks like it's coming from the center.It starts to leak when I fill it and continues to the end of the spin cycle.I was told it may be the main tub seal.If so,do I take off the outer tub or do it from the transmission?If I have to take off the outer tub how do I do that?
Ads By Google Related Models Last edited by jeanne : 08-14-2007 at 06:16 PM. |
Jeanne, looks like your problem is exactly like mine. It is easy to open the whole washer cabinet. I just watched YouTube.com video, search for how to repair washer and you will find many. Most likely cause for continually leaking washer is drain pump that costs from 15 to 30 bucks on e B a y or /elsewhere and seems easy to replace. In my case I opened and found the pump actually having leaks in its plastic case! Anyway my issue is that my drain pump is stuck to the motor. So came hwre to see if others had such issue ....
Good luck.... Regards Nik |
| Display Modes | |
| Washer leaking | cmklyne | Washer Repair | 1 | 09-24-2009 03:59 PM |
| Kenmore elite washer is leaking under washer | cbs | Washer Repair | 1 | 07-12-2009 06:27 PM |
| leaking washer | kalethedog | Washer Repair | 1 | 06-22-2009 05:06 PM |
| leaking washer | mdssales | Washer Repair | 3 | 09-19-2008 08:14 AM |
| Leaking Washer | GREGG GEE | Washer Repair | 1 | 11-29-2007 01:39 PM |
