Start as usual. The drum never begins initial spin for weight of load, and water never begins to enter washer. I do hear all the "clicks" I have usually heard when I press start and timer does cycle down through wash cycle, but no water & tumble. Water is on from source, no blockages in drain hose & hose is at same level it has been since initial install in June 2008.
Checked water supply. Everything ok. Checked any filter screens in supply hoses & the input to the water dispencer. All ok. I do not get 120 volts to the solenoids when turned on & start cycle started. Any suggestions?
