Discuss
Doesn't always spin (Running out of ideas)
 in
Washer Repair
Problem occurs on both Perm. Press and Regular cycles. Problem does NOT seem to be related to load size. Washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Doesn't always spin (Running out of ideas)
  #1 (permalink)
Old 04-23-2014, 06:17 PM
Junior Member
sparkyguy is on a distinguished road
Default Doesn't always spin (Running out of ideas)
Model Number: LSC8245AW0   Brand: Whirlpool   Age: More than 10 years
Washer ALWAYS functions perfectly until it reaches spin cycles. About 1/2 of the time, it "sounds" like the spin cycle kicks in (can hear motor running and pump will empty tub), but it does NOT spin. As such, at the end of the load, clothes are still sopping wet. If I reset timer to spin again, it will ALWAYS proceed properly thru the spin-cycle then shut off. Over a year and a half, I've replaced the following parts without resolving the issue:
1. Entire clutch assembly (actually replaced it TWICE over a year and a half)
2. Rubber motor coupling
3. Basket drive and brake assembly
4. Main drive motor, and line-connector
5. Motor start capacitor
There isn't much else I haven't replaced in the drive-line. I can hear the motor spinning, but it will often NOT spin the tub. Can the transmission on these units "slip"? Without taking it apart, the transmission appears to be a basic right-angle drive. If so, I would expect it would either work fine, or not at all (if stripped inside). When I replaced the Basket Drive and Brake Assembly, I cleaned and inspected the drive block and nothing appeared broken or stripped. Also, why does it ALWAYS seem to spin if I just reset the timer and start the spin cycle again?
Suggestions appreciated. Fixing this issue has become an obsession with me.
Related Models
Whirlpool LSC8245AW0 Washers*
Whirlpool LSC8245BW0 Washers*
Whirlpool LSC9000PW0 AUTOMATIC WASHER
Whirlpool LSC9000PW1 AUTOMATIC WASHER
Whirlpool LSC9000PW2 AUTOMATIC WASHER
Whirlpool LSC9245BN0 AUTOMATIC WASHER
Whirlpool LSC9245BN1 AUTOMATIC WASHER
Whirlpool LSC9245BQ0 AUTOMATIC WASHER
Whirlpool LSC9245BQ1 AUTOMATIC WASHER
Whirlpool LSC9245BW0 AUTOMATIC WASHER
Whirlpool LSC9245BW1 AUTOMATIC WASHER
Whirlpool LSC9245BZ0 AUTOMATIC WASHER
Whirlpool LSC9245BZ1 AUTOMATIC WASHER
Whirlpool LSC9355AG0 AUTOMATIC WASHER
Whirlpool LSC9355AN0 AUTOMATIC WASHER
Whirlpool LSC9355AW0 Washers*
Whirlpool LSC9355BN0 AUTOMATIC WASHER
Whirlpool LSC9355BN1 AUTOMATIC WASHER
Whirlpool LSC9355BQ0 AUTOMATIC WASHER
Whirlpool LSC9355BQ1 AUTOMATIC WASHER
Whirlpool LSC9355BW0 AUTOMATIC WASHER
Whirlpool LSC9355BW1 AUTOMATIC WASHER
Whirlpool LSC9355BZ0 AUTOMATIC WASHER
Whirlpool LSC9355BZ1 AUTOMATIC WASHER
Whirlpool LSC9355DQ0 AUTOMATIC WASHER
Whirlpool LSC9355DZ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ1 DIRECT-DRIVE WASHER
Whirlpool LSC9355EZ0 AUTOMATIC WASHER
Whirlpool LSC9355EZ1 DIRECT-DRIVE WASHER
Admiral LSD2615HEB REF - SXS/I&W
Admiral LSD2615HEW REF - SXS/I&W
Admiral LSD2615HEZ REF - SXS/I&W
Maytag LSE1000 STACKED LAUNDRY- ELE
Maytag LSE1000T Stacked Laundry - Ele
Jenn-Air LSE2700W STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-8 STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-C STACKED LAUNDRY- ELE
Jenn-Air LSE2704W STACKED LAUNDRY- ELE
Jenn-Air LSE2704W-8 STACKED LAUNDRY- ELE
Maytag LSE7800 STACKED LAUNDRY- ELE
Maytag LSE7800ACE STACKED LAUNDRY- ELE
Maytag LSE7800ACL STACKED LAUNDRY- ELE
Maytag LSE7800ACW STACKED LAUNDRY- ELE
Maytag LSE7800ADE STACKED LAUNDRY- ELE
Maytag LSE7800ADL STACKED LAUNDRY- ELE
Maytag LSE7800ADW STACKED LAUNDRY- ELE
Maytag LSE7800AEE STACKED LAUNDRY- ELE
Maytag LSE7800AEL STACKED LAUNDRY- ELE
Maytag LSE7800AEW STACKED LAUNDRY- ELE
Admiral LSE7800AGE STACKED LAUNDRY- ELE
Admiral LSE7800AGL STACKED LAUNDRY- ELE
Maytag LSE7804ACE STACKED LAUNDRY- ELE
Maytag LSE7804ACL STACKED LAUNDRY- ELE
Maytag LSE7804ACM STACKED LAUNDRY- ELE
Maytag LSE7804ADE STACKED LAUNDRY- ELE
Maytag LSE7804ADL STACKED LAUNDRY- ELE
Maytag LSE7804ADM STACKED LAUNDRY- ELE
Maytag LSE7804AEE STACKED LAUNDRY- ELE
Admiral LSE7804AGE STACKED LAUNDRY- ELE
Admiral LSE7804AGL STACKED LAUNDRY- ELE
Admiral LSE7804AGM STACKED LAUNDRY- ELE
Maytag LSE7806ACE STACKED LAUNDRY- ELE
Maytag LSE7806ACM STACKED LAUNDRY- ELE
Maytag LSE7806ACQ STACKED LAUNDRY- ELE
Maytag LSE7806ADE STACKED LAUNDRY- ELE
Maytag LSE7806ADM STACKED LAUNDRY- ELE
Maytag LSE7806ADQ STACKED LAUNDRY- ELE
Maytag LSE7806AEE STACKED LAUNDRY- ELE
Maytag LSE7806BCE STACKED LAUNDRY- ELE
Admiral LSE7806GGE STACKED LAUNDRY- ELE
Whirlpool LSE9355BQ0
Whirlpool LSE9355BZ0
Maytag LSE9900 STACKED LAUNDRY- ELE
Maytag LSE9900ACE STACKED LAUNDRY- ELE
Maytag LSE9900ACL STACKED LAUNDRY- ELE
Maytag LSE9900ACW STACKED LAUNDRY- ELE
Maytag LSE9900ADE STACKED LAUNDRY- ELE
Maytag LSE9900ADL STACKED LAUNDRY- ELE
Maytag LSE9900ADW STACKED LAUNDRY- ELE
Maytag LSE9900AEE STACKED LAUNDRY- ELE
Maytag LSE9900AEL STACKED LAUNDRY- ELE
Maytag LSE9900AEW STACKED LAUNDRY- ELE
Maytag LSE9900AFL STACKED LAUNDRY- ELE
Maytag LSE9900AFW STACKED LAUNDRY- ELE
Maytag LSE9904ACE STACKED LAUNDRY- ELE
Maytag LSE9904ACL STACKED LAUNDRY- ELE
Maytag LSE9904ACM STACKED LAUNDRY- ELE
Maytag LSE9904ADE STACKED LAUNDRY- ELE
Maytag LSE9904ADL STACKED LAUNDRY- ELE
Maytag LSG1000 STACKED LAUNDRY- GAS
Maytag LSG1000T Stacked Laundry - Gas
Jenn-Air LSG2700W STACKED LAUNDRY- GAS
Jenn-Air LSG2704W STACKED LAUNDRY- GAS
Maytag LSG7800 STACKED LAUNDRY- GAS
Maytag LSG7800AAE STACKED LAUNDRY- GAS
Maytag LSG7800AAL STACKED LAUNDRY- GAS
Maytag LSG7800AAW STACKED LAUNDRY- GAS
Maytag LSG7800ABE STACKED LAUNDRY- GAS
Maytag LSG7800ABL STACKED LAUNDRY- GAS
Maytag LSG7800ABW STACKED LAUNDRY- GAS
Maytag LSG7804AAE STACKED LAUNDRY- GAS
Maytag LSG7804AAL STACKED LAUNDRY- GAS
Maytag LSG7804AAM STACKED LAUNDRY- GAS
Maytag LSG7804ABE STACKED LAUNDRY- GAS
Maytag LSG7804ABL STACKED LAUNDRY- GAS
Maytag LSG7804ABM STACKED LAUNDRY- GAS
Maytag LSG7806AAE STACKED LAUNDRY- GAS
Maytag LSG7806AAM STACKED LAUNDRY- GAS
Maytag LSG7806AAQ STACKED LAUNDRY- GAS
Maytag LSG7806ABE STACKED LAUNDRY- GAS
Maytag LSG7806ABM STACKED LAUNDRY- GAS
Maytag LSG7806ABQ STACKED LAUNDRY- GAS
Maytag LSG9900 STACKED LAUNDRY- GAS
Maytag LSG9900AAE STACKED LAUNDRY- GAS
Maytag LSG9900AAL STACKED LAUNDRY- GAS
Maytag LSG9900AAW STACKED LAUNDRY- GAS
Maytag LSG9900ABE STACKED LAUNDRY- GAS
Maytag LSG9900ABL STACKED LAUNDRY- GAS
Maytag LSG9900ABW STACKED LAUNDRY- GAS
  #2 (permalink)
Old 04-24-2014, 05:55 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Could be the timer or the transmission. The transmission is of the neutral drain type. After agitation stops, the motor starts again in the opposite direction causing drain only for 2 minutes. During this time the transmission is in neutral. After the 2 minute drain, the timer causes the motor to stop and then start again. This causes the transmission to shift out of neutral so that when motor starts, spin engages while pump still drains. If there is no pause after drain, the timer is faulty and washer will just simply drain only during the entire spin cycle. You can open/close the lid to cause motor to pause. If timer is causing a pause after drain but washer still will not go into spin, the netural drain mechanism may be faulty or possibly the oil needs changing. The neutral drain mechanism is replaceable as are most all parts of the transmission. The transmission is not as simple as you think. Here is the parts manual for your model with transmission parts breakdown on the last page.
http://shared.whirlpoolcorp.com/asse...-%20881036.pdf
Eric
  #3 (permalink)
Old 04-24-2014, 06:41 PM
Junior Member
Default
Thanks for the reply.
After some additional digging, I was able to find a YouTube video of the transmission internals and how it actually functions. I found it most interesting (as I am a retired design engineer) and had not yet noticed that the motor reversed direction for agitation vs spin. I've repaired almost every appliance in the house and I'm also an auto gear-head (rebuilt a lot of engines, etc.) so once I saw how it actually worked it wasn't too intimidating IF I needed to dig into it. However, (as you noted), I closely watched the clutch and noticed that the motor did NOT pause as it supposed to shortly before starting to spin. It just has one extended DRAIN cycle and leaves the clothes wet. Further, THAT would explain why opening the lid would make it BEGIN to spin EVERY time because that action will temporarily stop the motor simulating the missing timer "pause". Conclusion: I ordered a timer about 2 hours before receiving your reply. However, it was still comforting that it seems my analysis agreed with your suggestions. Excluding this issue, 'Ol Whirlly has been quite reliable considering it is an OLD machine. For the most part, the internals still look almost new.
  #4 (permalink)
Old 04-29-2014, 06:49 AM
Junior Member
Default
--FIXED --
Confirming for Forum, I DID have bad timer. It was NOT a mechanical issue with any of my drive components even though I've been messing with them for years. It drove me nuts locating this problem on this appliance.
If it helps anyone else, the ONLY symptom I had which indicated it could be a bad timer was that it did NOT pause (and would skip the accompanying "thunk" sound at that point) right after the final drain cycle and right before the start of the final spin cycle. It would simply have one L-O-N-G final drain cycle and then stop (with soggy clothes still inside). Apparently, the motor must stop for a second or two to allow the clutch to engage and my defective timer has a bad contact inside which initiates that pause.
  #5 (permalink)
Old 04-29-2014, 07:56 AM
Expert
APP Volunteer
Default
Yes, I had already explained the required pause after drain. This causes the latch on the neutral drain mechanism to release from a cam on the bottom of the large plastic spin gear. That cam keeps the spin pawl from engaging the spin gear while in neutral drain. After latch disengages from cam, the spin pawl can now engage one of three bosses on the bottom of the spin gear so that gear is now driven, driving the spin pinion gear which drives the clutch.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer does not spin on the last cycle. Motor is running, but the drum is not moving C Norton Washer Repair 0 04-03-2014 08:21 AM
spin cycle water running cmk85212 Washer Repair 1 10-11-2011 07:02 PM
code nd with motor running but will not spin or drain Nomad1 Washer Repair 1 12-06-2009 07:11 PM
washer cycles spin cycle when running DBoelman Refrigerator & Freezer Repair 0 11-15-2009 03:13 PM
