| » Washer stops whene it should pump out water |
Model Number: LSR 5232 LQ1 Brand: Whirlpool Age: 1 - 5 years
i have a washer that just stops everytime when it should pump out water. There is no sound from the timer when it stops, and this will happend in every one of the programs I have on the washer. I can force it to start, on the next step in the program, but it will not pump out the wather, and after a while it will stop.
bj Related Models |
Most likely the problem is a bad lid switch.
- The part number for the lid switch is AP3100003 Here are the break down diagrams for the Whirlpool washer Model LSR5232LQ1 Gene.
__________________
Professional appliance repair in Orange County, California. |
Thanks for the tips.
I have waited a long time, but it is not starting up again. Gene; I wonder if you have an idea if I can check the lid swich. I live in easter Hodnuras and it is a long way to and service, I probably have to order the parts from USA and ship them down. So I would like to be shure what's the cause of the problem. Lappe |
Hi Lappe,
Open the control panel, disconnect the lid switch plug and bypass the lid switch. There are three wires and one of them has a green color. This is the ground wire. To bypass the lid switch you have to use two other wires (I do not remember their colors). Gene.
__________________
| Display Modes | |
| GE top load washer will not pump out water | cluelessdave | Washer Repair | 2 | 01-31-2010 06:24 AM |
| Whirlpool stops when time to pump out water | davecjr | Washer Repair | 3 | 03-27-2009 07:16 PM |
| Washer will not pump out water | woodworkingdan@sbcglobal. | Washer Repair | 1 | 03-26-2009 06:02 PM |
| Washer will not pump out water in spin | Blue Bear | Washer Repair | 0 | 07-24-2008 06:08 AM |
| Washer will not spin or pump out water | mcwasher | Washer Repair | 3 | 07-23-2008 11:28 AM |
