LG TROMM Model WM2277HW SN 407KW01565 Purchased Sept. 2004 Video of problem: LG Washer LE Error and Motor Noise - YouTubeLE error code after washer runs for a few minutes. Washer appears to be struggling to turn the drum. Strange noises I believe to be something like electrical pulses. Not metal on metal noise. The drum rotates smoothly and quietly by hand. The motor area looks like new. No metal particle dust. It seemed to get worse after I removed the motor rotor, blew out a few dust bunnies, and re-installed the motor rotor. Now the rotor intermittently does not turn at all and just buzzes. Should I try the Rotor Position / HALL Sensor first? Thank you for the excellent YouTube videos.
