Discuss
Kenmore stackable
 in
Washer Repair
Unit has been working fine. A few days ago it started making a very noticeable squeaking noise mid cycle. It
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore stackable
  #1 (permalink)
Old 04-12-2014, 01:09 PM
Junior Member
redhead's is on a distinguished road
Question Kenmore stackable
Model Number: 41798702891   Brand: Kenmore   Age: More than 10 years
Unit has been working fine. A few days ago it started making a very noticeable squeaking noise mid cycle. It did complete the cycle. Earlier today, I began to smell a burning smell, in addition to the squeak. I immediately turned it off and unplugged it.
Is this the belt needing to be replaced, or adjusted?
Related Models
Kenmore 41798702891 LAUNDRY CENTER
Kenmore 41798702892 LAUNDRY CENTER
Kenmore 41798802890 LAUNDRY CENTER
Kenmore 41798802891 LAUNDRY CENTER
Kenmore 41798804890 LAUNDRY CENTER
Kenmore 41798804891 LAUNDRY CENTER
Kenmore 41798862890 LAUNDRY CENTER
Kenmore 41798862891 LAUNDRY CENTER
Kenmore 41798864890 LAUNDRY CENTER
Kenmore 41798864891 LAUNDRY CENTER
Kenmore 41798988100 ELECTRIC DRYER
Kenmore 41798988110 ELECTRIC DRYER
Kenmore 41798988120 ELECTRIC DRYER
Kenmore 41798988130 ELECTRIC DRYER
Kenmore 41798988140 ELECTRIC DRYER
Kenmore 41798988150 ELECTRIC DRYER
Kenmore 41798988800 ELECTRIC DRYER
Kenmore 41798988810 ELECTRIC DRYER
Kenmore 41798988820 ELECTRIC DRYER
Kenmore 41798988830 ELECTRIC DRYER
Kenmore 41798988840 ELECTRIC DRYER
Kenmore 41798988850 ELECTRIC DRYER
Kenmore 41798989100 GAS DRYER
Kenmore 41798989110 GAS DRYER
Kenmore 41798989120 GAS DRYER
Kenmore 41798989130 GAS DRYER
Kenmore 41798989140 GAS DRYER
Kenmore 41798989150 GAS DRYER
Kenmore 41798989800 GAS DRYER
Kenmore 41798989810 GAS DRYER
Kenmore 41798989820 GAS DRYER
Kenmore 41798989830 GAS DRYER
Kenmore 41798989840 GAS DRYER
Kenmore 41798989850 GAS DRYER
Kenmore 41799160100 LAUNDRY CENTER
Kenmore 41799160110 LAUNDRY CENTER
Kenmore 41799160120 LAUNDRY CENTER
Kenmore 41799160130 LAUNDRY CENTER
Kenmore 41799160800 LAUNDRY CENTER
Kenmore 41799160810 LAUNDRY CENTER
Kenmore 41799160820 LAUNDRY CENTER
Kenmore 41799160830 LAUNDRY CENTER
Kenmore 41799165100 LAUNDRY CENTER
Kenmore 41799165110 LAUNDRY CENTER
Kenmore 41799165120 LAUNDRY CENTER
Kenmore 41799165130 LAUNDRY CENTER
Kenmore 41799165800 LAUNDRY CENTER
Kenmore 41799165810 LAUNDRY CENTER
Kenmore 41799165820 LAUNDRY CENTER
Kenmore 41799165830 LAUNDRY CENTER
Kenmore 41799170100 LAUNDRY CENTER
Kenmore 41799170110 LAUNDRY CENTER
Kenmore 41799170120 LAUNDRY CENTER
Kenmore 41799170800 LAUNDRY CENTER
Kenmore 41799170810 LAUNDRY CENTER
Kenmore 41799170820 LAUNDRY CENTER
Kenmore 41799175100 LAUNDRY CENTER
Kenmore 41799175110 LAUNDRY CENTER
Kenmore 41799175120 LAUNDRY CENTER
Kenmore 41799175800 LAUNDRY CENTER
Kenmore 41799175810 LAUNDRY CENTER
Kenmore 41799175820 LAUNDRY CENTER
Kenmore 41799180100 GAS AND ELECTRIC LAUNDRY CENTER
Kenmore 41799180110 LAUNDRY CENTER
Kenmore 41799180120 LAUNDRY CENTER
Kenmore 41799180800 GAS AND ELECTRIC LAUNDRY CENTER
Kenmore 41799180810 LAUNDRY CENTER
Kenmore 41799180820 LAUNDRY CENTER
Kenmore 41799185100 LAUNDRY CENTER
Kenmore 41799185110 27" LAUNDRY CENTER
Kenmore 41799185120 LAUNDRY CENTER
Kenmore 41799185800 LAUNDRY CENTER
Kenmore 41799185810 27" LAUNDRY CENTER
Kenmore 41799185820 LAUNDRY CENTER
Kenmore 41799190100 LAUNDRY CENTER
Kenmore 41799190110 27" LAUNDRY CENTER
Kenmore 41799190120 LAUNDRY CENTER
Kenmore 41799190800 LAUNDRY CENTER
Kenmore 41799190810 27" LAUNDRY CENTER
Kenmore 41799190820 LAUNDRY CENTER
Kenmore 41799195100 LAUNDRY CENTER
Kenmore 41799195110 LAUNDRY CENTER
Kenmore 41799195120 LAUNDRY CENTER
Kenmore 41799195800 LAUNDRY CENTER
Kenmore 41799195810 LAUNDRY CENTER
Kenmore 41799195820 LAUNDRY CENTER
Kenmore 41799370100 LAUNDRY CENTER
Kenmore 41799370110 LAUNDRY CENTER
Kenmore 41799370120 LAUNDRY CENTER
Kenmore 41799370130 LAUNDRY CENTER
Kenmore 41799370800 LAUNDRY CENTER
Kenmore 41799370810 LAUNDRY CENTER
Kenmore 41799370820 LAUNDRY CENTER
Kenmore 41799370830 LAUNDRY CENTER
Kenmore 41799375100 LAUNDRY CENTER
Kenmore 41799375110 27" LAUNDRY CENTER
Kenmore 41799375120 LAUNDRY CENTER
Kenmore 41799375800 LAUNDRY CENTER
Kenmore 41799375810 27" LAUNDRY CENTER
Kenmore 41799375820 LAUNDRY CENTER
Kenmore 41799390100 LAUNDRY CENTER
Kenmore 41799390110 LAUNDRY CENTER
Kenmore 41799390120 27" LAUNDRY CENTER
Kenmore 41799390130 LAUNDRY CENTER
Kenmore 41799390800 LAUNDRY CENTER
Kenmore 41799390810 LAUNDRY CENTER
Kenmore 41799390820 27" LAUNDRY CENTER
Kenmore 41799390830 LAUNDRY CENTER
Kenmore 41799395100 LAUNDRY CENTER
Kenmore 41799395110 LAUNDRY CENTER
Kenmore 41799395120 LAUNDRY CENTER
Kenmore 41799395800 LAUNDRY CENTER
Kenmore 41799395810 LAUNDRY CENTER
Kenmore 41799395820 LAUNDRY CENTER
Kenmore 41799463100 LAUNDRY CENTER
Kenmore 41799463110 LAUNDRY CENTER
Kenmore 41799463120 LAUNDRY CENTER
Kenmore 41799463800 LAUNDRY CENTER
Kenmore 41799463810 LAUNDRY CENTER
Kenmore 41799463820 LAUNDRY CENTER
  #2 (permalink)
Old 04-12-2014, 04:23 PM
Member
mr_mjsjr is on a distinguished road
Default
remove and examine the belt; insure that it not cracked, melted or excessively glazed. rotate the trans pulley, to insure it rotates freely. make sure the idler pulley has good tension and rotates freely. if everything checks okay, try increasing the tension on the idler. if the belt seems bad, replace the belt. if the idler seems bad, replace the idler. if the trans pulley drags a little or the unit seemed loud the bearing is probably bad(usually there is some water leakage or signs of oil having flung around). if the trans pulley turns hard or won't turn at all there may be something caught between the inner basket and outer tub or the trans is bad.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore stackable washer off balance bikerhaven Washer Repair 5 04-07-2013 08:52 AM
Kenmore Stackable Laundry Center stocktongoodrepair Washer Repair 0 01-04-2013 07:43 AM
Kenmore stackable leaking Geadvantium Washer Repair 3 03-17-2012 09:34 AM
kenmore stackable washer/dryer karns7 Washer Repair 2 06-09-2011 07:47 AM
kenmore stackable washer/dyer lovelyladymeka Washer Repair 0 10-24-2010 10:43 AM
