Have a Maytag A8640 that is 19 years old and sometimes get a lot of vibration on the spin cycle! When I look down the top of the agiator I can see a lot of black goo or something that does not look right. I poked a screw driver down and removed some and it is like a heavy grease. The agiator wobbles a little also. The machine is level and stable. Can I assume the agiator is worn and should be replaced or is it time for a new machine.
