Discuss
what could be wrong
 in
Washer Repair
This machine is an Equator Clothes-Processor Automatic Combination Washer and Tumble Dryer. I don't use the dryer though. Following is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » what could be wrong
  #1 (permalink)
Old 04-10-2014, 08:49 PM
Junior Member
ljlaw9 is on a distinguished road
Default what could be wrong
Model Number: EZ 3600C   Brand: -other-   Age: More than 10 years
This machine is an Equator Clothes-Processor Automatic Combination Washer and Tumble Dryer. I don't use the dryer though. Following is a description of what happened at last use.
Started a load of laundry. It stopped when it hit rinse. I waited about 5 minutes, but it still did nothing, so I turned the dial a teeny bit and it started to spin, but then stopped. I turned the dial a bit more and it started to rinse, then stopped. Turned it a bit more and it did the same. When it hit the spin cycle it was spinning like normal, but then started to smell really bad. Like a burning motor. So I quickly turned it off. The barrel appears to be empty of water at least and the clothes were dry enough to hang, but something isn't quite right.
Any ideas out there?
Thanks.
Related Models
Hardwick F-150 RANGE- F/S STD ELE
Hardwick F-414 SURFACE UNIT- GAS
Hardwick F-434 SURFACE UNIT- GAS
Hardwick F-436 SURFACE UNIT- GAS
Hardwick F-444 SURFACE UNIT- GAS
Hardwick F-446 SURFACE UNIT- GAS
Frigidaire F04B322BDA Frg(v1) / Electric Range
Frigidaire F04B322BDB Frg(v1) / Electric Range
Frigidaire F04B322BDC Frg(v1) / Electric Range
Frigidaire F04B322BWA Frg(v2) / Electric Range
Frigidaire F04B322BWB Frg(v2) / Electric Range
Frigidaire F04B322BWC Frg(v2) / Electric Range
Frigidaire F04B350BDA Frg(v1) / Electric Range
Frigidaire F04B350BDB Frg(v1) / Electric Range
Frigidaire F04B350BDC Frg(v2) / Electric Range
Frigidaire F04B350BDD Frg(v1) / Electric Range
Frigidaire F04B350BWA Frg(v2) / Electric Range
Frigidaire F04B350BWB Frg(v3) / Electric Range
Frigidaire F04B350BWC Frg(v4) / Electric Range
Frigidaire F04B350BWD Frg(v2) / Electric Range
Frigidaire F04B350EDA Frg(v1) / Electric Range
Frigidaire F04B350EDB Frg(v1) / Electric Range
Frigidaire F04B350EDC Frg(v2) / Electric Range
Frigidaire F04B350EWA Frg(v2) / Electric Range
Frigidaire F04B350EWB Frg(v3) / Electric Range
Frigidaire F04B350EWC Frg(v4) / Electric Range
Frigidaire F04B357BDA Frg(v1) / Electric Range
Frigidaire F04B357BDB Frg(v1) / Electric Range
Frigidaire F04B357BDC Frg(v1) / Electric Range
Frigidaire F04B357BDE Frg(v1) / Electric Range
Frigidaire F04B357BDF Frg(v1) / Electric Range
Frigidaire F04B357BDG Frg(v1) / Electric Range
Frigidaire F04B357BWA Frg(v2) / Electric Range
Frigidaire F04B357BWB Frg(v2) / Electric Range
Frigidaire F04B357BWC Frg(v2) / Electric Range
Frigidaire F04B357BWE Frg(v2) / Electric Range
Frigidaire F04B357BWF Frg(v2) / Electric Range
Frigidaire F04B357BWG Frg(v2) / Electric Range
Frigidaire F04C322BSA Frg(v3) / Electric Range
Frigidaire F04C322BSB Frg(v3) / Electric Range
Frigidaire F04C352BSA Frg(v3) / Electric Range
Frigidaire F04C352BSB Frg(v1) / Electric Range
Frigidaire F04C352BSC Frg(v1) / Electric Range
Frigidaire F04C352BTA Frg(v4) / Electric Range
Frigidaire F04C352BTB Frg(v2) / Electric Range
Frigidaire F04C352BTC Frg(v2) / Electric Range
Frigidaire F04C367BBA Frg(v1) / Electric Range
Frigidaire F04C367BSA Frg(v2) / Electric Range
Frigidaire F04C367BSB Frg(v1) / Electric Range
Frigidaire F04C367BTA Frg(v3) / Electric Range
Frigidaire F04C367BTB Frg(v2) / Electric Range
Frigidaire F04S350BDA Frg(v5) / Electric Range
Frigidaire F04S350BDB Frg(v1) / Electric Range
Frigidaire F04S350BWA Frg(v6) / Electric Range
Frigidaire F04S350BWB Frg(v2) / Electric Range
Jenn-Air F100 RANGE- F/S STD DDRAFT ELE
Jenn-Air F120 RANGE- F/S STD DDRAFT ELE
Jenn-Air F121 RANGE- F/S STD DDRAFT ELE
Amana F1320E MWAVE - FAMILY SIZE (60 HZ)
Amana F1320W MWAVE - FAMILY SIZE (60 HZ)
Amana F1331E Mwave - Family Size (60 Hz)
Amana F1331E MWAVE - FAMILY SIZE (60 HZ)
Amana F1331W Mwave - Family Size (60 Hz)
Amana F1331W MWAVE - FAMILY SIZE (60 HZ)
Amana F1340E MWAVE- CNTRTP / STAND ALONE
Amana F1340L MWAVE- CNTRTP / STAND ALONE
Amana F1340W MWAVE- CNTRTP / STAND ALONE
Amana F1361E Mwave - Family Size (60 Hz)
Amana F1361E MWAVE - FAMILY SIZE (60 HZ)
Amana F1361W Mwave - Family Size (60 Hz)
Amana F1361W MWAVE - FAMILY SIZE (60 HZ)
Amana F1560E MWAVE- CNTRTP / STAND ALONE
Amana F1560L MWAVE- CNTRTP / STAND ALONE
Amana F1560W MWAVE- CNTRTP / STAND ALONE
Amana F1961C MWAVE- CNTRTP / STAND ALONE
Amana F1961E Mwave - Family Size (60 Hz)
Amana F1961E MWAVE - FAMILY SIZE (60 HZ)
Amana F1961L Mwave - Family Size (60 Hz)
Amana F1961L MWAVE - FAMILY SIZE (60 HZ)
Amana F1961SS Mwave - Family Size (60 Hz)
Amana F1961SS MWAVE - FAMILY SIZE (60 HZ)
Amana F1961W Mwave - Family Size (60 Hz)
Amana F1961W MWAVE - FAMILY SIZE (60 HZ)
Hoover F2003--- FLR-POLISHER,SHAMPOO,CONDITINER
Hoover F2003001
Hoover F2003101
Hoover F2101--- FLR-POLISHER,SHAMPOO,CONDITINER
Hoover F2101073 FLR-POLISHER,SHAMPOO,CONDITINER
Frigidaire F21C235CS0 Frg(v1) / 27 " Washer
Frigidaire F21C235CS1 Frg(v0) / Washer
Frigidaire F21C235CS2 Frg(v1) / Washer
Frigidaire F21C235CT0 Frg(v2) / 27 " Washer
Frigidaire F21C235CT2 Frg(v2) / Washer
Frigidaire F21C445CS0 Frg(v3) / 27 " Washer
Frigidaire F21C445CS1 Frg(v1) / Washer
Frigidaire F21C445CS2 Frg(v1) / Washer
Frigidaire F21C445CS3 Frg(v1) / Washer
Frigidaire F21C445CT0 Frg(v4) / 27 " Washer
Frigidaire F21C445CT2 Frg(v2) / Washer
Frigidaire F21C445CT3 Frg(v2) / Washer
Frigidaire F21C645CS0 Frg(v5) / 27 " Washer
Frigidaire F21C645CS1 Frg(v2) / Washer
Frigidaire F21C645CS2 Frg(v0) / Washer
Frigidaire F21C645CS3 Frg(v1) / Washer
Frigidaire F21C645CT0 Frg(v6) / 27 " Washer
Frigidaire F21C645CT3 Frg(v2) / Washer
Jenn-Air F220 RANGE- F/S STD DDRAFT ELE
Jenn-Air F221 RANGE- F/S STD DDRAFT ELE
Frigidaire F22C233ES0 Frg(v0) / Washer
Frigidaire F22C445ES0 Frg(v0) / Washer
Frigidaire F22CW10
Frigidaire F22CW11
Frigidaire F22CW12
Crosley F22CW13 ARTIC AIR/FREEZER
Frigidaire F22CW2
Frigidaire F22CW3
Frigidaire F22CW4
Frigidaire F22CW6
Frigidaire F22CW7
Frigidaire F22CW8
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Not sure what's wrong... Myfirstwasher Washer Repair 0 04-13-2013 12:04 PM
Wrong #'s Doug Ingram Oven Repair (including Ranges and Cooktops) 0 06-02-2012 04:58 PM
What is wrong lloydo Microwave Repair 0 07-10-2011 12:08 PM
what's wrong AARON baseball Oven Repair (including Ranges and Cooktops) 1 12-02-2009 02:34 PM
What is wrong? kctso Washer Repair 0 09-18-2009 03:17 PM
