Discuss
Whirlpool Cabrio Washing Machine Won't Spin
 in
Washer Repair
I have a Whirlpool Cabrio top-loading washing machine model # WTW5640XW0 with a belt-driven transmission. I have read many of
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Cabrio Washing Machine Won't Spin
  #1 (permalink)
Old 04-10-2014, 11:13 AM
Junior Member
Toni J. is on a distinguished road
Default Whirlpool Cabrio Washing Machine Won't Spin
Model Number: WTW5640XW0   Brand: Whirlpool   Age: 1 - 5 years
I have read many of the posts, but found none with a problem quite like this one.
When it does into the spin cycle, the drum starts turning; the lid lock starts flashing, and it shuts off.
There are no fault codes registered. I put it in the manual test mode and ran through all the sequences. They all preformed properly, except the spin test shut down the washer as described above. The UI test was good. The Tachometer Verification Mode worked as it should. All voltages are correct. All wire harnesses were checked for continuity and are okay. The motor windings are within specifications. The capacitor check out okay. All tests were performed on the main circuit board with no problems found. The drum and transmission belt pulley turn together. I tired jamming the transmission to keep it from turning to see if there was a break, and there was not. I took the shifter clutch apart, and all the gearing was okay.
My neighbor has the same washing machine. I took the shift actuator with optical sensor off mine and put it on his. It worked without any problem. I reinstalled his actuator and did the same thing with my main circuit board. It worked fine. I ran the Calibration Mode with each change.
The drum turns freely with ease. The only problem I can detect is that it's making a grinding/scrapping noise compared to my neighbor's. It sounds like a bearing going bad, but to me, not to the point to make it quit working without a fault code indicating a basket speed problem.
Any suggestions on why it isn't working properly? Considering all the problems being reported on this model, is it time to scrap it?
Related Models
Whirlpool WTW5640XW0 AUTOMATIC WASHER
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
Whirlpool WTW5900TW0 AUTOMATIC WASHER
Whirlpool WTW6200SW0 AUTOMATIC WASHER
Whirlpool WTW6200SW1 AUTOMATIC WASHER
Whirlpool WTW6200SW2 AUTOMATIC WASHER
Whirlpool WTW6200SW3 AUTOMATIC WASHER
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
Whirlpool WTW6300SG0 AUTOMATIC WASHER
Whirlpool WTW6300SG1 AUTOMATIC WASHER
Whirlpool WTW6300SG2 AUTOMATIC WASHER
Whirlpool WTW6300SW0 AUTOMATIC WASHER
Whirlpool WTW6300SW1 AUTOMATIC WASHER
Whirlpool WTW6300SW2 AUTOMATIC WASHER
Whirlpool WTW6300WW0 AUTOMATIC WASHER
Whirlpool WTW6340WW0 AUTOMATIC WASHER
Whirlpool WTW6400SW0 AUTOMATIC WASHER
Whirlpool WTW6400SW1 AUTOMATIC WASHER
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
Whirlpool WTW6500WW1 AUTOMATIC WASHER
Whirlpool WTW6600SB0 AUTOMATIC WASHER
Whirlpool WTW6600SB1 AUTOMATIC WASHER
Whirlpool WTW6600SB2 AUTOMATIC WASHER
Whirlpool WTW6600SB3 AUTOMATIC WASHER
Whirlpool WTW6600SG0 AUTOMATIC WASHER
Whirlpool WTW6600SG1 AUTOMATIC WASHER
Whirlpool WTW6600SG2 AUTOMATIC WASHER
Whirlpool WTW6600SG3 AUTOMATIC WASHER
Whirlpool WTW6600SW0 AUTOMATIC WASHER
Whirlpool WTW6600SW1 AUTOMATIC WASHER
Whirlpool WTW6600SW2 AUTOMATIC WASHER
Whirlpool WTW6600SW3 AUTOMATIC WASHER
Whirlpool WTW6700TU1 AUTOMATIC WASHER
Whirlpool WTW6700TU2 AUTOMATIC WASHER
Whirlpool WTW6700TW0 AUTOMATIC WASHER
Whirlpool WTW6700TW1 AUTOMATIC WASHER
Whirlpool WTW6700TW2 AUTOMATIC WASHER
Whirlpool WTW6800WB1 AUTOMATIC WASHER
Whirlpool WTW6800WE1 RESIDENTIAL WASHER
Whirlpool WTW6800WL1 AUTOMATIC WASHER
Whirlpool WTW6800WU1 RESIDENTIAL WASHER
Whirlpool WTW6800WW1 AUTOMATIC WASHER
Whirlpool WTW7300XW0 AUTOMATIC WASHER
Whirlpool WTW7300XW1 AUTOMATIC WASHER
Whirlpool WTW7300XW2 AUTOMATIC WASHER
Whirlpool WTW7320YW0 WASHER
Whirlpool WTW7340XW0 AUTOMATIC WASHER
Whirlpool WTW7340XW1 AUTOMATIC WASHER
Whirlpool WTW7340XW2 AUTOMATIC WASHER
Whirlpool WTW7600XW0 AUTOMATIC WASHER
Whirlpool WTW7600XW1 AUTOMATIC WASHER
Whirlpool WTW7600XW2 AUTOMATIC WASHER
Whirlpool WTW7800XB0 AUTOMATIC WASHER
Whirlpool WTW7800XB1 AUTOMATIC WASHER
Whirlpool WTW7800XB2 AUTOMATIC WASHER
Whirlpool WTW7800XB3 AUTOMATIC WASHER
Whirlpool WTW7800XB4 AUTOMATIC WASHER
Whirlpool WTW7800XL0 AUTOMATIC WASHER
Whirlpool WTW7800XL1 AUTOMATIC WASHER
Whirlpool WTW7800XL2 AUTOMATIC WASHER
Whirlpool WTW7800XL3 AUTOMATIC WASHER
Whirlpool WTW7800XL4 AUTOMATIC WASHER
Whirlpool WTW7800XW0 AUTOMATIC WASHER
Whirlpool WTW7800XW1 AUTOMATIC WASHER
Whirlpool WTW7800XW2 AUTOMATIC WASHER
Whirlpool WTW7800XW3 AUTOMATIC WASHER
Whirlpool WTW7800XW4 AUTOMATIC WASHER
Whirlpool WTW7990XG0 AUTOMATIC WASHER
Whirlpool WTW7990XG1 AUTOMATIC WASHER
Whirlpool WTW8200YW0 AUTOMATIC WASHER
Whirlpool WTW8240YW0 AUTOMATIC WASHER
Whirlpool WTW8600YW0 AUTOMATIC WASHER
Whirlpool WTW8800YC0 WASHER
Whirlpool WTW8800YW0 WASHER
Bosch WTZ1170
Bosch WTZ1210
Roper WU0800B UNDERCOUNTER DISHWASHER
Roper WU0800XX0 Dishwasher
Roper WU0800XX1 UNDERCOUNTER DISHWASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool washing machine will not spin out everytime rdgiles1 Washer Repair 1 04-16-2013 10:13 AM
Whirlpool Cabrio Washing Machine mesmts11 Washer Repair 1 04-15-2013 05:22 PM
Whirlpool Duet Washing Machine Stops during Spin Cycle John43 Washer Repair 0 05-02-2010 10:19 AM
washing machine will not spin robins Washer Repair 1 11-05-2009 05:07 PM
Washing Machine doesn't spin CSand Washer Repair 1 05-29-2009 07:10 PM
