aford89
#1 Posted : Wednesday, April 9, 2014 5:51:11 PM(UTC)
aford89
I have a fridgidare stacked washer and dryer gallery series. it goes all the way thru the cycle just fine and drains but then when it comes to the final spin it almost acts as if its agitating still and never actually does the final spin. i checked both drain hoses in and out and nothing was blocking it. I am out of ideas and i cant find a model number anywhere on the machine itself i've checked behind the door and behind the main panel
sidfink43
#2 Posted : Thursday, April 10, 2014 4:39:23 PM(UTC)
sidfink43
This sounds like it may be the control unit, but you really need the model number so we can look further and if you have to order parts so you can order the right one.
aford89
#3 Posted : Thursday, April 10, 2014 6:15:03 PM(UTC)
aford89
any other ideas on where i could look for a model number? i honestly see no numbers on this machine at all
sidfink43
#4 Posted : Friday, April 11, 2014 4:16:32 AM(UTC)
sidfink43
Gosh if it is not on the inside of the dryer door I don't know where it might be.
aford89
#5 Posted : Saturday, April 12, 2014 4:03:12 PM(UTC)
aford89
finally found a part number! GLEH1642DS1 is the model we have that is having the problem
sidfink43
#6 Posted : Saturday, April 12, 2014 5:23:51 PM(UTC)
sidfink43
Okay good!
I am going to link you to the service manual
http://www.emaservicetips.com/p...thTumbleActionWasher.pdf
and it will show you where the tech sheet is, along with how to get into the unit. The motor/speed control board is often the problem on these models, so start there.
You may have to replace parts like the timer and speed board on spec, but if you buy from this site (no we don't work for them) and you do not need the parts you can return them.
Good luck!
