Discuss
Washer will not rinse or spin
 in
Washer Repair
the washer works great in agitate mode then drains water but will not fill with water in order to rinse.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not rinse or spin
  #1 (permalink)
Old 04-09-2014, 10:11 AM
Junior Member
Ktaka23 is on a distinguished road
Default Washer will not rinse or spin
Model Number: FWX833AS1   Brand: Frigidaire   Age: 1 - 5 years
the washer works great in agitate mode then drains water but will not fill with water in order to rinse. The tub just sits there with no water...then there is smoke coming from the behind the washer and a burning smell. Please help.
Related Models
Frigidaire FWX833AS1 Washer - Frigidaire
Frigidaire FWX833AS2 Frigidaire/washer
Frigidaire FWX833AS3 Frigidaire/washer
Frigidaire FWX833MAS0 Frigidaire/washer
Frigidaire FWX833SAQ0 Washer - Frig/gallery
Frigidaire FWX833SAS0 Washer - Frig/gallery
Frigidaire FWXB23RGS0 Frg(v0) / Washer
Frigidaire FWXB45RGS0 Washer - Frig/best Buy
Frigidaire FWXB45RGS1 Washer - Frig/best Buy
Frigidaire FWY833KAS0 Frigidaire/washer
Frigidaire FWY833KCS0 Frigidaire/washer
Frigidaire FXP18B4AW0 REFRIGERATOR
Frigidaire FXP18B4AW1 FRIGIDAIRE/REFRIGERATOR
Hardwick G-433 SURFACE UNIT- ELE
Hardwick G-436 SURFACE UNIT- ELE
Hardwick G-445 SURFACE UNIT- ELE
Jenn-Air G0206B-8 ELECTRIC GRILL OUTDOOR
Jenn-Air G100 SURFACE UNIT- DDRAFT ELE
Jenn-Air G101 SURFACE UNIT- DDRAFT ELE
Jenn-Air G102 SURFACE UNIT- DDRAFT ELE
Jenn-Air G103 SURFACE UNIT- DDRAFT ELE
Admiral G1110PRA RANGE- F/S STD GAS
Admiral G1110PRW RANGE- F/S STD GAS
Frigidaire G12W
Frigidaire G15W
Frigidaire G18W
Whirlpool G20EFSB2313 REFRIGERATOR
Whirlpool G20EFSB23S4 REFRIGERATOR
Whirlpool G20EFSB23S5 REFRIGERATOR
Whirlpool G20EFSB23S6 REFRIGERATOR
Whirlpool G20EFSB23S7 REFRIGERATOR
Whirlpool G20EFSB23S8 REFRIGERATOR
Whirlpool G20EFSB23S9 REFRIGERATOR
Frigidaire G21CL0 Frg(v1) / Gas Range
Frigidaire G21CW0 Frg(v2) / Gas Range
Frigidaire G21CW2 Frg(v1) / Gas Range
Frigidaire G21CW3 Frg(v2) / Gas Range
Frigidaire G21PCL0 Frg(v1) / Gas Range
Frigidaire G21PCL1 Frg(v3) / Gas Range
Frigidaire G21PCL3 Frg(v2) / Gas Range
Frigidaire G21PCL4 Frg(v2) / Gas Range
Frigidaire G21PCL5 Frg(v4) / Gas Range
Frigidaire G21PCW0 Frg(v2) / Gas Range
Frigidaire G21PCW1 Frg(v4) / Gas Range
Frigidaire G21PCW3 Frg(v1) / Gas Range
Frigidaire G21PCW4 Frg(v1) / Gas Range
Frigidaire G21PCW5 Frg(v3) / Gas Range
Frigidaire G22W
Frigidaire G24CL0 Frg(v1) / Free Standing Gas Range
Frigidaire G24CL3 Frg(v2) / Gas Range
Frigidaire G24CL4 Frg(v4) / Gas Range
Frigidaire G24CW0 Frg(v2) / Free Standing Gas Range
Frigidaire G24CW3 Frg(v1) / Gas Range
Frigidaire G24CW4 Frg(v3) / Gas Range
Frigidaire G24PCL0 Frg(v3) / Gas Range
Frigidaire G24PCL1 Frg(v5) / Gas Range
Frigidaire G24PCL3 Frg(v2) / Gas Range
Frigidaire G24PCL4 Frg(v4) / Gas Range
Frigidaire G24PCW0 Frg(v4) / Gas Range
Frigidaire G24PCW1 Frg(v6) / Gas Range
Frigidaire G24PCW3 Frg(v1) / Gas Range
Frigidaire G24PCW4 Frg(v3) / Gas Range
Frigidaire G25BNL0 Frg(v2) / Gas Range
Frigidaire G25BNW0 Frg(v1) / Gas Range
Whirlpool G25EFSB2313 REFRIGERATOR
Whirlpool G25EFSB23S4 REFRIGERATOR
Whirlpool G25EFSB23S5 REFRIGERATOR
Whirlpool G25EFSB23S6 REFRIGERATOR
Whirlpool G25EFSB23S7 REFRIGERATOR
Whirlpool G25EFSB23S8 REFRIGERATOR
Whirlpool G25EFSB23S9 REFRIGERATOR
Whirlpool G2IXEFMWB00 REFRIGERATOR
Whirlpool G2IXEFMWB01 REFRIGERATOR
Whirlpool G2IXEFMWB02 REFRIGERATOR
Whirlpool G2IXEFMWB03 REFRIGERATOR
Whirlpool G2IXEFMWQ00 REFRIGERATOR
Whirlpool G2IXEFMWQ01 REFRIGERATOR
Whirlpool G2IXEFMWQ02 REFRIGERATOR
Whirlpool G2IXEFMWQ03 REFRIGERATOR
Whirlpool G2IXEFMWS00 REFRIGERATOR
Whirlpool G2IXEFMWS01 REFRIGERATOR
Whirlpool G2IXEFMWS02 REFRIGERATOR
Whirlpool G2IXEFMWS03 REFRIGERATOR
Frigidaire G30BCL2 Frg(v2) / Gas Range
Frigidaire G30BCW1 Frg(v1) / Gas Range
Frigidaire G30CL0 Frg(v5) / Gas Range
Frigidaire G30CL2 Frg(v2) / Gas Range
Frigidaire G30CL3 Frg(v4) / Gas Range
Frigidaire G30CW0 Frg(v6) / Gas Range
Frigidaire G30CW2 Frg(v1) / Gas Range
Frigidaire G30CW3 Frg(v3) / Gas Range
Frigidaire G30LPNL1 Frg(v2) / Gas Range
Frigidaire G30LPNL2 Frg(v2) / Gas Range
Frigidaire G30LPNL3 Frg(v2) / Gas Range
Frigidaire G30LPNW1 Frg(v1) / Gas Range
Frigidaire G30LPNW2 Frg(v1) / Gas Range
Frigidaire G30LPNW3 Frg(v1) / Gas Range
Frigidaire G30NL1 Frg(v1) / Gas Range
Frigidaire G30NL2 Frg(v2) / Gas Range
Frigidaire G30NL3 Frg(v3) / Gas Range
Frigidaire G30NL4 Frg(v4) / Gas Range
Frigidaire G30NL5 Frg(v2) / Gas Range
Frigidaire G30NL6 Frg(v2) / Gas Range
Frigidaire G30NL7 Frg(v4) / Gas Range
Frigidaire G30NW1 Frg(v5) / Gas Range
Frigidaire G30NW2 Frg(v6) / Gas Range
Frigidaire G30NW3 Frg(v7) / Gas Range
Frigidaire G30NW4 Frg(v8) / Gas Range
Frigidaire G30NW5 Frg(v1) / Gas Range
Frigidaire G30NW6 Frg(v1) / Gas Range
Frigidaire G30NW7 Frg(v3) / Gas Range
Frigidaire G30PCL0 Frg(v7) / Gas Range
Frigidaire G30PCL1 Frg(v7) / Gas Range
Frigidaire G30PCL3 Frg(v2) / Gas Range
Frigidaire G30PCW0 Frg(v8) / Gas Range
Frigidaire G30PCW1 Frg(v8) / Gas Range
Frigidaire G30PCW3 Frg(v1) / Gas Range
Frigidaire G30PNL1 Frg(v2) / Gas Range
Frigidaire G30PNL2 Frg(v2) / Gas Range
Frigidaire G30PNL3 Frg(v4) / Gas Range
  #2 (permalink)
Old 04-10-2014, 05:37 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Okay this is somewhat of a mystery since first of all it works through the wash cycle which suggests that there is nothing mechanically wrong with the machine, and second, all that has to happen is for the inlet valve to open to let cold water in to rinse.
If you are using only hot water for wash, try a wash cycle on the cold water and see if it fills. If it does not and you get the smoke and burning smell the problem could be in the inlet valve assembly or the timer, but most likely the valve assembly. To test, hook up the cold water connectors at the valve assembly to the hot water and see if it fills on cold water wash. If so that wold confirm the valve assembly as the problem. If not, the timer is likely the issue.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Fills, Agitates, does final Spin but no Pre Rinse Cycle Spin rruzzo Washer Repair 2 04-01-2013 04:45 PM
Whirlpool washer won't spin on rinse cycle or high spin bry21317 Washer Repair 10 05-24-2011 12:25 PM
ge washer will not rinse or spin tmm313psu Washer Repair 1 10-04-2009 07:45 AM
washer won't rinse or spin an1sa2 Washer Repair 5 08-04-2009 05:53 PM
Washer goes to rinse cycle then spin back to rinse, stuck in this mod Pat66 Washer Repair 1 05-08-2009 07:44 AM
