Discuss
Whirlpool Washer Noisy and Won't Spin
 in
Washer Repair
Whirlpool direct drive washer was making noise and wouldn't agitate or spin. Agitator dogs were bad and were replaced with
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer Noisy and Won't Spin
  #1 (permalink)
Old 04-08-2014, 11:46 AM
Junior Member
voncass is on a distinguished road
Default Whirlpool Washer Noisy and Won't Spin
Model Number: LLR9245BQ1   Brand: Whirlpool   Age: More than 10 years
Whirlpool direct drive washer was making noise and wouldn't agitate or spin. Agitator dogs were bad and were replaced with repair kit. Now it agitates fine but makes noise while doing it. Still won't spin and makes noise when it should be spinning. No unusual smell or smoke. Is there a way to test for bad coupling or bad clutch? Could it be the transmission? Is there a way to test trans?
Related Models
Whirlpool LLR9245BQ1 WASHERS DIRECT-DRIVE
Whirlpool LLR9245DQ0
Whirlpool LLR9245DQO WHIRLPOOL WASHER
Whirlpool LLR9245DZ0
Whirlpool LLR9245DZO WHIRLPOOL WASHER
Whirlpool LLT7144AN0 Washers*
Whirlpool LLT7144BN0
Whirlpool LLT7144BQ0
Whirlpool LLT7144BQ1
Whirlpool LLT7144BW0
Whirlpool LLT7144DQ0
Whirlpool LLT8233AN0
Whirlpool LLT8233AQ0
Whirlpool LLT8233AW0
Whirlpool LLT8233AW1 AUTOMATIC WASHER
Whirlpool LLT8233AW2
Whirlpool LLT8233DQ0
Whirlpool LLT8233DZ0
Whirlpool LLT8244AN0
Whirlpool LLT8244AQ0
Whirlpool LLT8244AW0
Whirlpool LLT8244AZ0
Whirlpool LLT8244BQ0
Whirlpool LLT8244BQ1
Whirlpool LLT8244BZ0
Whirlpool LLT8244BZ1
Whirlpool LLT8244DQ0
Whirlpool LLT8244DZ0
Whirlpool LLV6144AG0
Whirlpool LLV6144AN0
Whirlpool LLV6144AW0
Whirlpool LLV6144BN0
Whirlpool LLV6144BW0
Whirlpool LLV7233AW0
Whirlpool LLV7244AG0
Whirlpool LLV7244AN0
Whirlpool LLV7244AW0
Whirlpool LLV8233BN0
Whirlpool LLV8233BQ0
Whirlpool LLV8233BW0
Whirlpool LLV8245AG0
Whirlpool LLV8245AN0
Whirlpool LLV8245AW0
Whirlpool LLV8245BN0
Whirlpool LLV8245BW0
Whirlpool LLV8245DQ0
Whirlpool LLV8245DZ0
 LM-1830C2L Air Conditioner
 LM-2430C2L Air Conditioner
 LM-2430H2L Air Conditioner
 LM360CE Air Conditioner
Whirlpool LMA1053LQ0
Whirlpool LMA1053LT0
 LMA1150SV Microwave Oven
 LMA1560SB Microwave Oven
 LMA2111ST Microwave Oven
 LMAN090CNS.ANCAEUS Air Conditioner
 LMAN090HNS Air Conditioner
 LMAN120CNS Air Conditioner
 LMAN120HNS Air Conditioner
 LMAN121CNM Air Conditioner
 LMAN121HNM Air Conditioner
 LMH1017CVST Microwave Oven
 LMN090CE.AWHAEUS Air Conditioner
 LMN090HE Air Conditioner
 LMN120EC.AWHAEUS Air Conditioner
 LMN120HE Air Conditioner
 LMN2430H2L Air Conditioner
Whirlpool LMR4131AN0
Whirlpool LMR4131AW0
Whirlpool LMR4132BW0
Whirlpool LMR4232AN0
Whirlpool LMR4232AW0
Whirlpool LMR5243AN0
Whirlpool LMR5243AN1
Whirlpool LMR5243AW0
Whirlpool LMR5243AW1
 LMU180HE Air Conditioner
 LMU1830C2L Air Conditioner
 LMU240CE.AWGAEUS Air Conditioner
 LMU240HE Air Conditioner
 LMU2430C2L Air Conditioner
 LMU360CE Air Conditioner
 LMU360HE Air Conditioner
 LMV-1975ST Microwave Oven
 LMV1314B Microwave Oven
 LMV1314SV Microwave Oven
 LMV1314W Microwave Oven
 LMV1625B Microwave Oven
 LMV1625W Microwave Oven
 LMV1630BB Microwave Oven
 LMV1630ST Microwave Oven
 LMV1630WW Microwave Oven
 LMV1635SB Microwave Oven
 LMV1635SBQ Microwave Oven
 LMV1635SW Microwave Oven
 LMV1680ST Microwave Oven
 LMV1680WW Microwave Oven
 LMV1825SB Microwave Oven
 LMV1825SBQ Microwave Oven
 LMV1915NVB Microwave Oven
 LMV1925SB Microwave Oven
 LMV1925SBQ Microwave Oven
 LMV1925SW Microwave Oven
 LMV1976ST Microwave Oven
 LMV2053SB Microwave Oven
 LMV2053ST Microwave Oven
 LMV2053SW Microwave Oven
 LMV2061SB Microwave Oven
 LMV2073BB Microwave Oven
 LMV2073ST Microwave Oven
 LMV2073WW Microwave Oven
 LMV2083SB Microwave Oven
 LMV2083ST Microwave Oven
 LMV2083SW Microwave Oven
Whirlpool LMV5243AN0
Whirlpool LMV5243AW0
  #2 (permalink)
Old 04-09-2014, 10:22 AM
Junior Member
Default Transmission
After disassembling the washer I've concluded it must be the transmission that's bad. Motor runs, coupler is good, pump not jammed, clutch looks good, etc. When I've hold the clutch housing and turn the coupler on the trans clockwise, the clutch housing tries to turn but gears slip inside the trans. Since the washer is 18 yr old instead of a new trans I'll junk the washer ever though it still looks new.
  #3 (permalink)
Old 04-10-2014, 05:01 AM
Junior Member
Default Wow
Wow, the response here to my thread has been overwhelming.
  #4 (permalink)
Old 04-10-2014, 05:24 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
If the washer is otherwise in good shape, it is well worth repairing versus buying the new junk they are selling today. You can replace the transmission or open it up to find the problem. Probably just a stripped spin gear (plastic) which is easily replaced and costs less than a new transmission.
Whirlpool 3360629 Neutral Drain Transmission - AppliancePartsPros.com
Whirlpool 285362 Gear and Pinon - AppliancePartsPros.com
This not a "staffed" forum. We are techs who volunteer our time here to help others. If you want "instant" service, there are paid sites for that.
Eric
  #5 (permalink)
Old 04-10-2014, 07:39 AM
Junior Member
Default thanks
Thank you. I was just frustrated it went two days without a reply from anyone. If I knew for certain that is all that's wrong with it I would repair the trans. But the coarse noise it makes while agitating and when it should be spinning (same noise) makes me think it could be the tub bearing too which I read is a big job to replace and isn't recommended without a new tub.
  #6 (permalink)
Old 04-10-2014, 10:49 AM
Expert
APP Volunteer
Default
You were reading about a model with a different drive train altogether. Your model does not have a tub bearing. The noise may be coming from your faulty transmission. Might recognize it if you post video to youtube.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Washer Noisy on spin stevepvm Washer Repair 1 09-17-2012 06:20 PM
Washer noisy on spin cycle jimII Washer Repair 2 08-30-2011 06:57 PM
Amana washer noisy during spin Jim Gaspar Washer Repair 1 08-01-2011 06:10 PM
Washer noisy on spin dpuccetti Washer Repair 0 03-01-2009 09:31 AM
washer noisy during spin djgabor Washer Repair 0 09-22-2007 12:03 PM
