benmcgraw
#1 Posted : Monday, April 7, 2014 8:43:54 AM(UTC)
benmcgraw
The cycle button allows only the choice of the Heavy Duty cycle. Repeated pressing results in no response. All other buttons cycle through all options normally. Does this indicate the control panel (F-18 on the diagram and which apparently is not available) is at fault?
mr_mjsjr
#2 Posted : Monday, April 7, 2014 4:25:56 PM(UTC)
mr_mjsjr
you can remove the toe panel and taped to the side wall there should be a tech sheet. it will tell you which ribbon cables to check for the cycle select button; but if everything else is operational with all other buttons working. it sounds like a user interface.
