Discuss
Whirlpool Washer lxr6232eq0 Motor won't work
 in
Washer Repair
Ok, so here's the results: Timer set on spin cycle, 120 volts a the motor plug to White, White/Black, and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer lxr6232eq0 Motor won't work
  #11 (permalink)
Old 04-11-2014, 04:50 PM
Junior Member
benwelder is on a distinguished road
Default
Ok, so here's the results: Timer set on spin cycle, 120 volts a the motor plug to White, White/Black, and Yellow. No power to the other wires.
This was with the meter to a neutral prong in an outlet, and the same results with it to one of the green ground wires to the washer frame.
  #12 (permalink)
Old 04-11-2014, 08:49 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Sounds like your receptacle is wired reverse polarity. Makes no difference to the washer as it would still work normally but you need to fix that receptacle wiring before continuing.
Eric
  #13 (permalink)
Old 04-12-2014, 04:12 AM
Junior Member
Default
If it makes a difference, I was incorrect, the meter was in the ground of the outlet. Not the neutral.
Does this still mean it's the timer you think?
  #14 (permalink)
Old 04-12-2014, 06:20 AM
Expert
APP Volunteer
Default
You should not be reading voltage to ground or neutral from motor connector white or white/black wires. I can't say with any certainty if your timer is bad or not based on the readings you are getting. You could try replacing it. If you buy from APP, you may return it if it doesn't fix the problem. You need to do some electrical troubleshooting and I can't teach that over this forum. It appears to me that your receptacle is wired wrong. Check voltage on receptacle between ground and the wide blade and ground and narrow blade. Which one do you get 120vac on?
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer drive motor wont work reymart Washer Repair 6 04-25-2013 05:20 AM
washer motor won't work shearon Washer Repair 3 02-01-2012 05:19 PM
washer motor won't work shearon Washer Repair 0 01-30-2012 08:41 PM
reset washer so motor will work jv4692 Washer Repair 0 03-23-2010 02:23 PM
Washer won't work on high motor scmajka Washer Repair 1 12-14-2008 04:25 AM
