My washer isn't spinning properly. We did the test program - started out showing error code 05, which indicated motor erratic - followed with test #3 motor - the motor initially spins to a high speed then spools down as if no electricity. This happens with belt off. Brushes were replaced 2yrs ago. Any help would be appreciated
