Tried to start the wash cycle. The washer initially locked and then immediately unlocked and would not start a cycle. Tried several times on different settings. Tried unplugging washer and starting again. Same thing each time. Husband tested lock and it did read a little low on ohm's, but then he tried one of the tests and it gave code E68, that said the heating element is bad. We are now at a loss as what to buy after reading that several people purchased new locks and that turned out not to be the problem. Is anyone able to perhaps tell us what the issue could be and how we can rectify it without spending a fortune...would a wise choice be to buy both parts and return the one we don't need. Also would anything else cause the washer to do this? Please help!! :( Need my washer back soon!!
