I have ge front loader washer. I have been having issues with this washer. First thing is. I had a leak coming from the drum. The ge tech came out and then took the washer. When it came back. The leak was fixed, but then i had to unplug the washer after a load was done and then plug it back in to do another load. So the tech came out again. Replaced the board and found out that the washer was not getting enough water. So he replaced the cylinoid. The washer fills fine now. So the tech left. I ran a load of clothes and thought everything was fine. Went to start another load and oh well crap. I have to unplug it again and plug it back in to do another load.. i am getting pretty mad!!! I wanted to see if anyone on here had any ideas before i call ge back. Thanx Pete
