The missus seemed to have in overloaded the machine with floor rugs. Consequently it would not spin and there was a strong burnt rubber smell. The drum would rotate by hand. Today I took off the front thinking it would be a belt malfunction, but it seems to be in good shape. I switched on the machine to spin cycle and the motor starts up, but there is no movement from the belt, also the drum now seems to have locked up.
Help please!
Also, I just checked the motor and it is extremely hot after trying to run the spin cycle for only a minute or two. And the belt pulley runs freely.
