73buick225
#1 Posted : Sunday, March 2, 2014 3:26:31 PM(UTC)
73buick225
This washer is just over two years old. Over the last year it has occasionally done this, but always seemed to correct itself, but now it seems more serious. We will start a load, it will fill up with water, then nothing. It won't agitate, drain or spin. Only sound is the hum of the dial (wife said it smelled like burnt cabbage when she first checked it).So I popped the service panel and took a look at the lid switch. That one blade seems to have some residue on it, and the plug did seem very slightly indented/melted and did smell slighlty burnt. Then I looked underneath. You can see the burn marks on the harness and that spade looks pretty burnt up. Pretty sure that blue wire goes up to the dial box which looks clean.
So, would this be a bad motor?
73buick225 attached the following image(s):
fairbank56
#2 Posted : Sunday, March 2, 2014 4:13:18 PM(UTC)
fairbank56
Groups: Expert
It could be a bad motor, faulty capacitor or faulty contact on the motor start switch which is inside that black receptacle (motor switch) on the motor. Yes, that blue wire is hot side power to the motor from the timer. The problem here is that you must replace that burned contact in the motor connector and lid switch connector and you will have to replace the motor switch as that burned contact is beyond refurbishing. Once you get the contacts back to normal and the motor switch replaced, you would need to check the motor current with amprobe to determine if motor itself has a problem or if there is something else wrong with the washer causing too much load on the motor. Finding someone to do this kind of work won't be easy, most tech's don't do that kind of repair. Your other option is to just replace the motor, capacitor, lid switch and complete wiring harness.
Eric
73buick225
#3 Posted : Sunday, March 2, 2014 5:07:07 PM(UTC)
73buick225
I didn't know about the capacitor before, so I took it out to take a look at it. I'll be able to put a meter on it tomorrow, but I noticed two things with it. One, there seems to be water around the terminals (could be the internal cap fluid, too, I made sure to wash my hands), and two, I had my wife smell it and its emanating the burnt cabbage odor she said she smelled before.
fairbank56
#4 Posted : Sunday, March 2, 2014 5:43:54 PM(UTC)
fairbank56
Groups: Expert
Have you had that motor replaced before? Doesn't look like it's the original motor. Is the part number on it 3951551? If it is, I would say that someone has replaced the original motor with that one. Did you buy the washer new or used?
This switch should fit your motor. Whirlpool 3952056 Main Drive Motor Switch - AppliancePartsPros.com
Eric
73buick225
#5 Posted : Monday, March 3, 2014 2:06:11 PM(UTC)
73buick225
Motor has never been replaced. Its only just over 2yrs old, bought new from HomeDepot.
73buick225
#6 Posted : Monday, March 3, 2014 4:26:42 PM(UTC)
73buick225
Okay, so I got a meter on the motor. Here are the readings: (Fluke 77 digital meter)
WhiteBlack to White: 0 ohms
Black to Yellow: 7 ohms
Blue to White: 1 ohm
Blue to WhiteBlack: 1 ohm
For the capacitor, here are the readings.
Initial: 3 Mohms
While holding leads about 15 seconds: went down to 2.2Mohms, then starting to creep back up.
Switched leads
Initial: -1.6 Mohms
While holding leads about 30 secons, went almost to about -0.3 Mohms, then went to positive 2.4 Mohms, went down to about 1.5, then started to creep up.
I'm going to bring the cap to my local appliance repair guy and have them check it too as they probably have an actual cap tester.
Also took a look at the insides of the start switch. Nothing looked melted. Took pump of quick, motor span freely, pump didn't seem jammed.
fairbank56
#7 Posted : Monday, March 3, 2014 7:21:01 PM(UTC)
fairbank56
Groups: Expert
Motor readings are within specs. Capacitor is suspect, need meter with capacitance test function.
Eric
