This front load washer is the manual model, no digital controls. It drains but quit spin dry cycle. Checked threads for info, found that door lock did not- replaced door lock and now that works, pumps out water correctly but still no spin! Does anyone have any ideas on what the trouble could be? I am not sure but I don't think this one has a motor speed board. The timer motor seems to be running, it clicks to the next item ok- the end buzz sounds. Washes, just won't spin!
Correction: It isn't turning at all now. No spin, No tumble
