Hi! Here's my situation:
My washer had been running all morning (5-6 loads). Then when I went to switch, the cycle was at off, but water was still in the tub.
At that point, the washer would not respond at any point on the dial. After I waited an hour thinking the motor might have overheated, the washer did work when I turned it back to a spin cycle, but the same thing happened and the water did not drain. (Just fyi...the dryer was running at the time the washer stopped so I know it is getting 220v.)
I would appreciate any guidance as to how to fix this asap. I have deduced that I may have clogged my drain pump, but I can't seem to find any pictures online or demonstrations to show/tell me how to even find the pump. I can answer any other questions or give any details I can. Thanks!!!
Melissa
