| » My washer won't drain |
Model Number: GLWS1339CS1 Brand: Frigidaire Age: 1 - 5 years
I recently moved and I just hooked up my washer and I find that it will fill with water, it will spin, but it won't drain. Can someone please tell me what to do or what the problem is.
You need to take off the front and do the following.
1. Check and make sure there is nothing obstructing the drain hoses. 2. If the system is clear, you should determine if power is getting to the pump while the timer is in a drain position. If it is, then the pump is probably the problem. 3. If power is not getting to the pump, the problem is likely in your timer or lid switch/lock assembly. Try to by pass the lid lock assembly, and if still does not get power you will probably need to replace the timer.
__________________
| Display Modes | |
| Washer does not drain | acer_620_u | Washer Repair | 1 | 12-09-2009 06:15 AM |
| washer does not drain | leh | Washer Repair | 0 | 08-22-2009 03:08 PM |
| Washer won't drain | aerrickson | Washer Repair | 2 | 05-17-2009 02:40 PM |
| GE Washer won't drain | Wannafix | Washer Repair | 0 | 06-12-2008 07:57 AM |
| Calypso Washer Washer Won't Drain | SamB | Washer Repair | 3 | 11-27-2007 01:41 PM |
