| » maytag washer/dyer combo |
LinkBack (1) | Thread Tools | Search this Thread | Display Modes |
Model Number: lsg7806aae Brand: Maytag Age: 5 - 10 years
when we turn on the controls, the only cycle that works is the spin cycle - washer doesn't go thruough any of the cycles except the spin cycle. we already replaced the water inlet valve and that didn't help. does it sound like the washer timer could be the problem? thank you!
Hi Jeff,
The first thing I would check is the fuse (#3 on the cabinet break down diagram). Here are the break down diagrams for the Maytag laundry center Model LSG7806AAE Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Jeff,
According to the break down diagram it's shown on the left side inside the washer cabinet. You have to remove the front panel to search for the fuse. Also the lid switch shown as an assembly with the fuse. It is confusing but I can not tell exactly where it is. Gene.
__________________
I have a problem like this a few months ago the problem was the lid switch assembly, this lid switch assembly has two switches in it, the smaller switch that has a little red piont on it that switch was defective.
these two switches the big one open the power circuit coming into the machine the small switch is wired directly through the water valve and the fuse,sometimes when this switch malfunction it will blow the fuse,the first time i ran into this problem i change the fuse and it just blew again when i start the machine. |
Hi Jeff,
Check the 12 wires connector between the control panel and the washer for loose and/or burned wires (especially the Blue and the Orange wires). Gene.
__________________
LinkBack to this Thread: http://forum.appliancepartspros.com/washer-repair/5462-maytag-washer-dyer-combo.html
| Posted By | For | Type | Date |
| Digg - maytag washer/dyer combo | This thread | Refback | 02-16-2008 05:29 PM |
| Display Modes | |
| kenmore washer dryer combo | joem | Washer Repair | 3 | 01-25-2008 05:09 PM |
| Estate Dyer making grinding noise | gsaldana71 | Dryer Repair | 1 | 12-28-2007 01:17 PM |
| gas dyer will not heat | tomfreez3@sbcglobal.net | Dryer Repair | 1 | 12-11-2007 02:21 PM |
| Removing Microwave from Oven Combo | diyall | Microwave Repair | 0 | 12-09-2007 08:22 AM |
| Microwave range hood combo | cakeman | Microwave Repair | 0 | 10-12-2007 08:33 AM |
