Will do everything but agitate. It tries but fails. Replaced the coupling about a year ago. Any thoughts?
Thank you in advance!
Groups: Expert
Model number??? What does it do when it should be agitating? Motor running? Humming? All quiet?
Eric
Thanks for the reply - it was the "dogs" in the agitator. Fixed and ready to go!
Thanks again!
Groups: Expert
Ah, the auger wasn't working, should have known, would have with model number. This is a two piece agitator. Lower agitator driven in both directions by transmission, upper (auger) driven in one direction only by lower agitator via the dogs. Common problem, easy fix. Good job.
Eric
