Carol & Bob
#1 Posted : Monday, February 17, 2014 7:47:33 AM(UTC)
Carol & Bob
I just replaced the rotor and stator on my washer because it was not spinning. When it spins now it makes a knocking noise coming from the new parts I put on. It used to make a howling noise like a quiet fire whistle.
LG washer not letting in cold water (Washer Repair)
by Cgrigson1 4/19/2024 7:34:57 AM(UTC)
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
LG Washer WM4270HVA/01 incomplete draining OE error (Washer Repair)
by PapawZooKeeper 6/18/2023 12:46:26 PM(UTC)
LG Washer - Rotor and Stator Grinding (Washer Repair)
by Guest 11/30/2022 7:57:29 PM(UTC)
wt7600hwa lg washer (Refrigerator & Freezer Repair)
by Guest 8/19/2022 7:47:52 AM(UTC)
LG Washer Error TE (Washer Repair)
by leonthepc 7/17/2022 1:34:39 PM(UTC)
WT5270CW LG Washer (Washer Repair)
by Gerald Shaffer 7/6/2022 12:59:29 PM(UTC)
LG Washer Drain Pump Noise (Washer Repair)
by Guest 1/28/2022 8:06:10 AM(UTC)
LG washer -Drum not spinning during rinse cycle with Fe error code (Washer Repair)
by Guest 12/29/2021 3:31:30 AM(UTC)
LG washer WM2050CW has water in it after not running for a day (Washer Repair)
by hklein 12/16/2021 4:48:27 PM(UTC)
LG washer tromm (Oven Repair (including Ranges and Cooktops))
by Guest 6/18/2021 5:43:36 AM(UTC)
LG washer not powering on (Washer Repair)
by diyer2018 6/13/2021 6:29:13 PM(UTC)
lg washer power when tub is spun by hand (Washer Repair)
by robin2741 3/29/2021 10:56:54 AM(UTC)
LG Washer WT1101CW (Washer Repair)
by rsrosenberg54 3/15/2021 6:53:23 AM(UTC)
LG Washer Repair (Washer Repair)
by 623-332-8543 1/10/2021 9:14:04 AM(UTC)
