| » Washer shuts prior to filling |
Model Number: 417 44052401 Brand: Kenmore Age: 1 - 5 years
When starting my Kenmore washer, the proper lights come on (including door locked light) and when I hit the start button you here the typical "click" sound followed by a delay. The delay is normal for a couple seconds and then the water usually starts filling. Now, the delay happens and then the machine just shuts off. This happens on every setting I have tried on the washer. I am thinking it might be either the switch on the door or perhaps the water valve in the machine. I did check the water supply to the machine and it appears OK. The only other odd thing is that there is a small magnet about 3/4" x 1/4" x 1/4" that was stuck to the inside of the door. I have no idea if it came from inside the machine (could be from one of my kids' pockets). Any help or suggestions would be greatly appreciated as my extended warranty ran out and a repairman is not an option at the moment. Thank you for your time.
Wilhelm Related Models |
If you take off the bottom panel you should find some tech notes that will take you through a trouble shooting routine.
I suspect the door lock mechanism is your problem, but the tech notes should enable you to confirm that.
__________________
| Display Modes | |
| Washer shuts off | sjlandau | Washer Repair | 1 | 10-27-2008 08:44 PM |
| Burning smell, shuts off after filling | dcmcfish | Washer Repair | 1 | 09-29-2008 10:31 AM |
| MW won't heat, had prior arcing sound | pennstatejeff | Microwave Repair | 7 | 03-12-2008 03:01 PM |
| Washer Filling enough? | crgauth | Washer Repair | 2 | 01-29-2008 07:07 PM |
| Reefer buzzing prior to start of cooling fan | peanut | Refrigerator & Freezer Repair | 0 | 12-29-2007 06:36 AM |
