Discuss
Kenmore washer agitates on heavy duty but not on permanent press or normal
 in
Washer Repair
Kenmore washer agitates on heavy duty but not on permanent press or normal This is before and after new timer!
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer agitates on heavy duty but not on permanent press or normal
  #1 (permalink)
Old 02-13-2008, 04:26 PM
okey okey is offline
Junior Member
okey is on a distinguished road
Default Kenmore washer agitates on heavy duty but not on permanent press or normal
Brand: Kenmore   Age: 1 - 5 years
Any ideas or suggestions greatly appreciated.
M/N 11092375100
  #2 (permalink)
Old 02-14-2008, 03:54 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
In order to provide the most accurate advise I need the complete model number of the washer.
__________________
  #3 (permalink)
Old 02-14-2008, 05:15 PM
Junior Member
Default
Quote:
M/N 11092375100
  #4 (permalink)
Old 02-14-2008, 06:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There is a two speed motor on your washer. Most likely it does not work on the high speed due to the bad high speed motor winding, loose connection at the motor plug or a broken wire.
- The part number for the motor is AP2905451
__________________
  #5 (permalink)
Old 02-14-2008, 08:04 PM
Junior Member
Default
Ill check it out tomorrow. With your help I know what to look for. Thanks a bunch!
  #6 (permalink)
Old 02-14-2008, 09:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
__________________
  #7 (permalink)
Old 02-14-2008, 09:42 PM
Junior Member
Default
I will. Thanks again.
  #8 (permalink)
Old 02-15-2008, 09:11 AM
Junior Member
Default
Well, I disassembled washer this morning and did not find any loose or broken wires. So I guess the motor is bad. However I did notice an electrical part (I think would be a capacitor, Part Number: AP3861916) near the motor. Could it be faulty?
Thanks,
Okey
  #9 (permalink)
Old 02-15-2008, 11:53 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The motor will not run at all with a bad capacitor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer agitates normal then slows down and stops. jnaylor Washer Repair 3 10-22-2007 08:14 PM
washer agitates but won't spin` mls6089 Washer Repair 0 10-12-2007 09:34 AM
electric dryer has no heat, but still runs in both permanent press and timed dry. chrisnross Dryer Repair 1 09-12-2007 06:51 AM
kenmore heavy duty 60 washing machine Ben Anson Washer Repair 1 08-10-2007 05:49 PM
Automatic Permanent Press Cycle fails to shut off DECALGUY Dryer Repair 3 08-04-2007 08:28 PM
