Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Kenmore washer agitates on heavy duty but not on permanent press or normal (http://forum.appliancepartspros.com/washer-repair/5457-kenmore-washer-agitates-heavy-duty-but-not-permanent-press-normal.html)
okey 02-13-2008 03:26 PM
This is before and after new timer!
Any ideas or suggestions greatly appreciated.
M/N 11092375100
Gene 02-14-2008 02:54 PM
In order to provide the most accurate advise I need the complete model number of the washer.
okey 02-14-2008 04:15 PM
Quote:
M/N 11092375100
Gene 02-14-2008 05:06 PM
There is a two speed motor on your washer. Most likely it does not work on the high speed due to the bad high speed motor winding, loose connection at the motor plug or a broken wire.
- The part number for the motor is AP2905451
okey 02-14-2008 07:04 PM
Ill check it out tomorrow. With your help I know what to look for. Thanks a bunch!
Gene 02-14-2008 08:35 PM
Keep me updated, please.
okey 02-14-2008 08:42 PM
Quote:
I will. Thanks again.
okey 02-15-2008 08:11 AM
Well, I disassembled washer this morning and did not find any loose or broken wires. So I guess the motor is bad. However I did notice an electrical part (I think would be a capacitor, Part Number: AP3861916) near the motor. Could it be faulty?
Thanks,
Okey
Gene 02-15-2008 10:53 AM
The motor will not run at all with a bad capacitor.
