| » Cloths come out wet |
Model Number: 11092583800 Brand: Kenmore Age: More than 10 years
Cloths come out still wet from final spin cycle, I did tried other spin cycles on the timer and it worked. Now it does not work on either of the spin cycles. Any Ideas?
Related Models |
Dose it spin at all?
__________________
Professional appliance repair in Orange County, California. |
I would recommend to remove the cabinet and check the pump and the drain hoses for clog and/or a foreign objects inside.
Also check for a foreign objects between the inner and the outer tubs. The outer tub made of clear plastic and you can see through it. These instructions will guide you through the disassemble procedure. Gene.
__________________
| Display Modes | |
| Washer intermitantly leaves cloths wet | james King | Washer Repair | 0 | 11-30-2007 01:29 PM |
| Need clean cloths, whirpool washer | smurzynski | Washer Repair | 1 | 08-06-2007 05:50 PM |
