I have the above listed model. I repair all kind of appliances but this is my first time repairing a frigidaire stackable. First how do I remove the cap located at the bottom of the drum? There are 2 arrows lined up, do I stick a screw driver in the hole an pop it off ? Or do the cap un screw off ? Trying to replace a bad seal causing water to leak out of the drum Any help would be greatful Thank you in advance
