Discuss
Maytag Neptune MAH8700AWM Control Panel Replacement
 in
Washer Repair
I've got a Maytag Neptune MAH8700AWM SN 12354141GR. Started getting the E3 error last fall. Motor tested good and would
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Neptune MAH8700AWM Control Panel Replacement
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-01-2014, 08:27 AM
Junior Member
tfmccall is on a distinguished road
Default Maytag Neptune MAH8700AWM Control Panel Replacement
Model Number: MAH8700AWM   Brand: Maytag   Age: 5 - 10 years
I've got a Maytag Neptune MAH8700AWM SN 12354141GR. Started getting the E3 error last fall. Motor tested good and would run fine after resetting, but it got worse. I checked all the connections, then replaced the motor (34001437, which superceded 34001405) hoping the Hall Effect was the issue (as the trouble shooting recommended). No help, but I could get things to go by tapping the top of the panel. I ordered a new control panel (34001495 which superceded 34001478), and after some wait finally got it in. This one comes with the new Motion Sensor. After installing, the motor bumps then locks, followed by the E3 error. I can't even get it to run in test mode. I've put the old panel back on and the motor runs fine in spin test. So we're continuing on with the occasional error, which we correct with some more tapping until the drum starts rotating. Once it starts, it's usually good for the portion of the cycle it's on, i.e. Wash, Rinse or Spin.
I'm at a loss, since everything has been replaced and I have no idea where to go from here. Replacing seems the easiest thing for this Samsung made Maytag, but my wife really likes this thing.
Any help would be appreciated.
Related Models
Maytag MAH8700AWM WASHER- HORIZONTAL AXIS
Maytag MAH8700AWW WASHER- HORIZONTAL AXIS
Maytag MAH9700AWM WASHER- HORIZONTAL AXIS
Maytag MAH9700AWQ WASHER- HORIZONTAL AXIS
Maytag MAH9700AWW WASHER- HORIZONTAL AXIS
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM MISC / ACCESSORY
Maytag MAL1800AXQ MISC / ACCESSORY
Maytag MAL1800AXW MISC / ACCESSORY
Maytag MAL2000AXQ MISC / ACCESSORY
Maytag MAL2000AXW MISC / ACCESSORY
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL MANUAL, PARTS (WASHER)
Maytag MAT10CSAAW MANUAL, PARTS (WASHER)
Maytag MAT10CSAGL MANUAL, PARTS (WASHER)
Maytag MAT10CSAGW MANUAL, PARTS (WASHER)
Maytag MAT10CSEGL MANUAL, PARTS (WASHER)
Maytag MAT10CSEGW MANUAL, PARTS (WASHER)
Maytag MAT10DAAAL MANUAL, PARTS (WASHER)
Maytag MAT10DAAAW MANUAL, PARTS (WASHER)
Maytag MAT10DAABL MANUAL, PARTS (WASHER)
Maytag MAT10DAABW MANUAL, PARTS (WASHER)
Maytag MAT10PDAAL MANUAL, PARTS (WASHER)
Maytag MAT10PDAAW MANUAL, PARTS (WASHER)
Maytag MAT10PDABL MANUAL, PARTS (WASHER)
Maytag MAT10PDABW MANUAL, PARTS (WASHER)
Maytag MAT10PDEGW MAYTAG LAUNDRY (COMM.EXPORT) (WASHER)
Maytag MAT10PSAAL MANUAL, PARTS (WASHER)
Maytag MAT10PSAAW MANUAL, PARTS (WASHER)
Maytag MAT10PSAGL MANUAL, PARTS (WASHER)
Maytag MAT10PSAGW MANUAL, PARTS (WASHER)
Maytag MAT11CSBKL MANUAL, PARTS (WASHER)
Maytag MAT11MNAAW MANUAL, PARTS (WASHER)
Maytag MAT11MNAGW MANUAL, PARTS (WASHER)
Maytag MAT11MNEGW MANUAL, PARTS (WASHER)
Maytag MAT11PDAAL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDAAW MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABW MAYTAG LAUNDRY (WASHER)
Maytag MAT12CSAAL MANUAL, PARTS (WASHER)
Maytag MAT12CSAAQ MANUAL, PARTS (WASHER)
Maytag MAT12CSAAW MANUAL, PARTS (WASHER)
Maytag MAT12CSAGW MANUAL, PARTS (WASHER)
Maytag MAT12CSAKL MANUAL, PARTS (WASHER)
Maytag MAT12CSAKQ MANUAL, PARTS (WASHER)
Maytag MAT12CSDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSEGW MANUAL, PARTS (WASHER)
Maytag MAT12CSFWQ COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSFWW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLGW MAYTAG COMMERCIAL WASHER (WASHER)
Maytag MAT12CSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDAAL MANUAL, PARTS (WASHER)
Maytag MAT12PDAAW MANUAL, PARTS (WASHER)
Maytag MAT12PDABL MANUAL, PARTS (WASHER)
Maytag MAT12PDABW MANUAL, PARTS (WASHER)
Maytag MAT12PDAGW MANUAL, PARTS (WASHER)
Maytag MAT12PDBAL MANUAL, PARTS (WASHER)
Maytag MAT12PDBAQ MANUAL, PARTS (WASHER)
Maytag MAT12PDBAW MANUAL, PARTS (WASHER)
Maytag MAT12PDBBL MANUAL, PARTS (WASHER)
Maytag MAT12PDBBQ WASHER-TOP LOADING
Maytag MAT12PDBBW MANUAL, PARTS (WASHER)
Maytag MAT12PDCBL MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDBW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDEGW MANUAL, PARTS (WASHER)
Maytag MAT12PDLAQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLAW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLGW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDSAW MANUAL,PARTS (WASHER)
Maytag MAT12PRAAW MANUAL, PARTS (WASHER)
Maytag MAT12PRAEW MANUAL, PARTS (WASHER)
Maytag MAT12PRBAW MANUAL, PARTS (WASHER)
Maytag MAT12PRDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PRSAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAGW MANUAL, PARTS (WASHER)
Maytag MAT12PSBAW MANUAL, PARTS (WASHER)
Maytag MAT12PSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT13MNAAW MANUAL, PARTS (WASHER)
Maytag MAT13MNAGW MANUAL, PARTS (WASHER)
Maytag MAT13MNDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNEGW MANUAL, PARTS (WASHER)
Maytag MAT13PDAAW MANUAL, PARTS (WASHER)
Maytag MAT13PDBAW MANUAL, PARTS (WASHER)
Maytag MAT13PNAEW MAYTAG LAUNDRY (WASHER)
Maytag MAT13PNDEW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13PRBWW MAYTAG LAUNDRY (WASHER)
Maytag MAT14CSAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSBGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14PDAWW0 COMMERCIAL AUTOMATIC WASHER
Whirlpool MAT14PDAXW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14PRAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNBGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT23PCAAG MANUAL, PARTS (WASHER)
Maytag MAT23PCAAL MANUAL, PARTS (WASHER)
Maytag MAT23PCAAW MANUAL, PARTS (WASHER)
Maytag MAT23PCABG MANUAL, PARTS (WASHER)
Maytag MAT23PCABL MANUAL, PARTS (WASHER)
Maytag MAT23PCABW MANUAL, PARTS (WASHER)
Maytag MAT25CSAAG MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAAL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAAW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAGG MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSAGL MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSAGW MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSBIL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Control Panel Replacement ductman Trash Compactor Repair 0 12-28-2012 02:17 AM
Maytag Neptune Washer Control Panel Delphicandy Washer Repair 2 11-15-2010 11:07 AM
neptune washer control panel will not work kdongs Washer Repair 1 09-13-2010 04:59 PM
Neptune control panel problem Greggy H Dryer Repair 1 09-12-2010 08:58 AM
maytag neptune washer control panel dmichael Washer Repair 12 12-14-2008 04:11 PM
