I have a maytag mah9700awm washer that I bought used. It wasn't working & the previous owner said they had a repairman look at it & he said it needed a new motor & control board. I checked the motor & the motor windings were broken so I replaced the motor but I am still getting multiple error codes. I get OE - fault in water level sensor, 22 - door switch detected open during cycle & 3E - motor failure overcurrent. After I replaced the motor I tried a cycle & the door locks & the tub begins to fill for approximately 15 sec & then the cycle stops & the door unlocks. Could a bad control board be the cause of all of the errors or am I dealing with 3 separate issues. Also the washer is actually 8 years old, not 5.
