Discuss
Replacing Lid Switch
 in
Washer Repair
Our Kenmore washer will not spin until you press hard on the corner of the lid where a prong contacts
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Replacing Lid Switch
  #1 (permalink)
Old 10-17-2009, 11:09 AM
mcguirejw mcguirejw is offline
Junior Member
mcguirejw is on a distinguished road
Default Replacing Lid Switch
Model Number: 110.29842991   Brand: Kenmore   Age: 5 - 10 years
Our Kenmore washer will not spin until you press hard on the corner of the lid where a prong contacts the lid switch. I figure I need to replace the switch and probably the prong (called a strike in my parts diagram) and bumper, too. But I cannot figure out how to get the top off the washer to replace the lid switch. How can I do this?
Related Models
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
Kenmore 110.5807961  KENMORE GAS DRYER
Kenmore 110.5808000  KENMORE ELECTRIC DRYER
Kenmore 110.5808010  KENMORE ELECTRIC DRYER
Kenmore 110.5808100  KENMORE ELECTRIC DRYER
Kenmore 110.5808300  KENMORE ELECTRIC DRYER
Kenmore 110.5808500  KENMORE ELECTRIC DRYER
Kenmore 110.5808700  KENMORE ELECTRIC DRYER
Kenmore 110.5808800  KENMORE ELECTRIC DRYER
Kenmore 110.5808810  KENMORE ELECTRIC DRYER
Kenmore 110.5808850  KENMORE ELECTRIC DRYER
Kenmore 110.5808860  KENMORE ELECTRIC DRYER
Kenmore 110.5808950  KENMORE ELECTRIC DRYER
Kenmore 110.5808960  KENMORE ELECTRIC DRYER
Kenmore 110.5817500  KENMORE GAS DRYER
Kenmore 110.5817501  KENMORE GAS DRYER
Kenmore 110.5817800  KENMORE GAS DRYER
Kenmore 110.5817801  KENMORE GAS DRYER
Kenmore 110.5817811  KENMORE GAS DRYER
Kenmore 110.5817820  KENMORE GAS DRYER
  #2 (permalink)
Old 10-17-2009, 11:40 AM
toddx toddx is offline
Junior Member
toddx is on a distinguished road
Default Replacing lid switch
The lid switch is accessible by lifting the top panel. There are two spring clips in the front that need to be pushed back to raise the top. The switch is held in by a couple of screws. If you're replacing the switch, you'll need to run the wire from the switch to the motor/control assembly.
-Todd
  #3 (permalink)
Old 10-17-2009, 02:47 PM
applianceman applianceman is offline
Senior Member
applianceman is on a distinguished road
Default
Quote:
You are correct the lid switch needs to be replaced. You are going to have to remove the case to replace the lid switch. This is easy first remove the covers off each end of the control panel to access the screws that holds the control panel in place. Then hinge the control panel up. Once done you should see two brass colored clips, remove them. The lid-switch-wires come up through the case in the center, unplug them. Once done you should be able to remove the entire case out from around the washer to replace the lid switch. For more on this along with some pictures use this link Whirlpool Washer Disassembly Guide
  #4 (permalink)
Old 10-18-2009, 08:51 AM
Junior Member
Default Removing end covers
Quote:
Thanks! At first I could not figure out how to remove the cover pieces but a little pressure applied to the bottom let them pop out. Now to order the parts!
  #5 (permalink)
Old 10-18-2009, 02:19 PM
Junior Member
Default
How can I tell if the strike/actuator on the washer lid is as long as it should be? If it somehow got shortened then the problem may not be the switch itself. Or even if the switch were replaced, the strike/actuator may not be quite long enough to engage it properly. If the little nylon or plastic part were only a buck or two I'd order it and not worry. But the durned thing costs $9.26, plus shipping if I have to order it later. The picture of the part on your website seems to have more pieces than the one on my machine. If you can see the same diagram (Sears Part No. 357141) as I, there is a larger white part on the right that I don't recognize. Also, my Sears repair parts list shows the strike and a bumper (354255). Are both included in the part on your website? It sort of looks that way but the guy on the phone today could not answer that question.
  #6 (permalink)
Old 10-18-2009, 07:40 PM
Senior Member
Default
As for what is included in the pack I can’t say because I don’t work for appliancepartspros.com. However it is unlikely that you need to replace the strike/actuator. Look closely at the strike on the washer lid you should be able to tell if it has broken off. In any case it should be around ½ inch give or take.
It is very common for the lid switch to wear out in a way that the switch needs to be pressed further and further until the strike can no longer activate the switch but pressing down on the lid will push it just a bit further so that it will activate the switch.
I am not saying that the strike isn’t bad and you shouldn’t consider it because I do see it occasionally. Just that in all likelihood it is the lid switch.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help Replacing Start Switch Tru2Chevy Dryer Repair 1 09-29-2009 05:57 PM
Replacing Refrigerator Light Switch chi_guy50 Refrigerator & Freezer Repair 4 09-01-2009 10:25 AM
replacing lid switch rutherford556 Washer Repair 1 07-22-2009 10:39 AM
replacing lid switch cbcolorado Washer Repair 1 05-31-2009 07:16 PM
Replacing the griddle infinite switch J Black Oven Repair (including Ranges and Cooktops) 1 11-19-2007 02:46 PM
