Discuss
Kenmore washer trips breaker on slow speed
 in
Washer Repair
My Kenmore washer works fine on the fast speed settings (Heavy Duty and Hang Dry cycles) but trips the breaker
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer trips breaker on slow speed
  #1 (permalink)
Old 01-18-2014, 02:21 PM
Junior Member
hrasco is on a distinguished road
Default Kenmore washer trips breaker on slow speed
Model Number: 110.92581100   Brand: Kenmore   Age: More than 10 years
My Kenmore washer works fine on the fast speed settings (Heavy Duty and Hang Dry cycles) but trips the breaker after running a few seconds on the slow speed settings (Normal and Gentle cycles). I have connected it to a different circuit and it trips that breaker as well. I have used it for more than 3 years using the Heavy Duty cycle but would like to have use of the gentler cycles. What could be wrong?
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 01-18-2014, 04:22 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
During the short time that the motor runs in slow speed, does it sound like its switching on/off repeatedly? Does a lamp plugged into same receptacle as washer repeatedly dim/brighten with washer running in slow speed?
Eric
  #3 (permalink)
Old 01-19-2014, 08:57 PM
Junior Member
Default
Quote:
Eric
Thanks for your reply. Sorry I wasn't able to tend to this sooner.
There is a slight dimming and quick recovery of a lamp on initial startup in both slow and fast speeds. There is no repeated dimming. In slow speed it runs about 15 -20 seconds and trips the breaker.
  #4 (permalink)
Old 01-20-2014, 05:31 AM
Expert
APP Volunteer
Default
Sounds like a motor problem but I would have to take some current and voltage readings to diagnose it for sure. If you buy a new motor from APP and it doesn't fix the problem, you may return it.
Whirlpool 661600 Direct Drive Washer Motor - AppliancePartsPros.com
Eric
  #5 (permalink)
Old 01-20-2014, 05:47 AM
Junior Member
Default
Eric
Thanks for your help
  #6 (permalink)
Old 01-20-2014, 06:02 AM
Junior Member
Default
Quote:
I am curious as to what could be happening that it runs for as long as it does before tripping the breaker. Any thoughts on this?
  #7 (permalink)
Old 01-20-2014, 08:26 AM
Expert
APP Volunteer
Default
If the current through your panel breaker is just exceeding it's rating, it can take some time before it will trip. It's not like it just trips instantly when the current goes over 15 amps if it's a 15 amp breaker.
I would examine the motor wiring connector. Power to the motor low speed run winding during low speed is via the orange wire which is right next to the neutral wire on that connection. Unplug the connector and check for blackening due to overheating from a bad connection. There may be bleedover there causing high current.
You really need an amprobe to find where the excessive current is if it's not obvious at the motor connector. Could be the orange wire is damaged somewhere along the run from timer to motor or even a problem in the timer. The motor normally draws 8-9 amps in high speed and maybe .5 amp or so less in low speed. If you were to check the current into the motor during low speed operation and it's fine, then the problem is elsewhere.
Could also be a bad speed select switch that's trying to power both run windings in the motor at the same time. If you provide a clear hi-res photo of your wiring diagram, I can tell you how to bypass the speed switch. I don't have the exact diagram for your washer. They all have slight differences. Does the back of your speed switch have individual wire terminals or a harness plug? Looks like probably a harness plug. A photo of the back of that switch would also be helpful.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer won't drain, starts spin cycle stops trips circuit breaker m789h Washer Repair 6 01-14-2011 06:38 PM
Kenmore trips breaker JustDave45 Dryer Repair 2 10-21-2009 03:39 PM
Kenmore washer trips breaker... E.J.W. Washer Repair 1 09-24-2009 04:08 PM
washer trips breaker ostoyichva Washer Repair 4 08-07-2009 05:33 PM
Trips breaker on slow cycle candu Washer Repair 2 12-18-2008 05:37 PM
