Discuss
Kenmore not agitating or spining?
 in
Washer Repair
Based on fact it won't agitate or spin, figuring it is a bad motor drive coupling? Someone mentioned it could
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore not agitating or spining?
  #1 (permalink)
Old 01-17-2014, 11:24 AM
Junior Member
wjob is on a distinguished road
Default Kenmore not agitating or spining?
Model Number: 11028922791   Brand: Kenmore   Age: 5 - 10 years
Based on fact it won't agitate or spin, figuring it is a bad motor drive coupling? Someone mentioned it could also be the "agitator dog"?
Will appreciate comments and if it is the agitator dog, what are the steps to replace?
thanks
Related Models
Kenmore 11028922791 AUTOMATIC WASHER
Kenmore 11028924790 AUTOMATIC WASHER
Kenmore 11028924791 AUTOMATIC WASHER
Kenmore 11028932790 AUTOMATIC WASHER
Kenmore 11028932791 AUTOMATIC WASHER
Kenmore 11028934790 AUTOMATIC WASHER
Kenmore 11028934791 AUTOMATIC WASHER
Kenmore 11028942890 Residential Washers
Kenmore 11028942891 AUTOMATIC WASHER
Kenmore 11028944890 Residential Washers
Kenmore 11028944891 AUTOMATIC WASHER
Kenmore 11028972890 AUTOMATIC WASHER
Kenmore 11028972891 AUTOMATIC WASHER
Kenmore 11028974890 AUTOMATIC WASHER
Kenmore 11028974891 AUTOMATIC WASHER
Kenmore 11029012990 COMMERICAL AUTOMATIC WASHER
Kenmore 11029032990 COMMERCIAL AUTOMATIC WASHER
Kenmore 11029072990 COMMERCIAL AUTOMATIC WASHER
Kenmore 11029422800 RESIDENTIAL WASHER
Kenmore 11029422801 RESIDENTIAL WASHER
Kenmore 11029432800 WASHER
Kenmore 11029432801 RESIDENTIAL WASHER
Kenmore 11029442800 RESIDENTIAL WASHER
Kenmore 11029442801 RESIDENTIAL WASHER
Kenmore 11029522800 RESIDENTIAL WASHER
Kenmore 11029522801 RESIDENTIAL WASHER
Kenmore 11029532800 RESIDENTIAL WASHER
Kenmore 11029532801 RESIDENTIAL WASHER
Kenmore 11029592800 RESIDENTIAL WASHER
Kenmore 11029592801 RESIDENTIAL WASHER
Kenmore 11029622800 RESIDENTIAL WASHER
Kenmore 11029622801 RESIDENTIAL WASHER
Kenmore 11029632800 RESIDENTIAL WASHER
Kenmore 11029632801 RESIDENTIAL WASHER
Kenmore 11029672800 RESIDENTIAL WASHER
Kenmore 11029672801 RESIDENTIAL WASHER
Kenmore 11029682800 RESIDENTIAL WASHER
Kenmore 11029682801 RESIDENTIAL WASHER
Kenmore 11029692800 RESIDENTIAL WASHER
Kenmore 11029692801 RESIDENTIAL WASHER
Kenmore 1102970093 COMPACT AUTOMATIC WASHER
Kenmore 11029722800 RESIDENTIAL WASHER
Kenmore 11029722801 RESIDENTIAL WASHER
Kenmore 11029727800 RESIDENTIAL WASHER
Kenmore 11029727801 RESIDENTIAL WASHER
Kenmore 11029732800 WASHER
Kenmore 11029732801 RESIDENTIAL WASHER
Kenmore 11029737800 WASHER
Kenmore 11029737801 RESIDENTIAL WASHER
Kenmore 11029802890 AUTOMATIC WASHER
Kenmore 11029812890 AUTOMATIC WASHER
Kenmore 11029812891 AUTOMATIC WASHER
Kenmore 11029822800 WASHER
Kenmore 11029822801 RESIDENTIAL WASHER
Kenmore 11029832800 WASHER
Kenmore 11029832801 RESIDENTIAL WASHER
Kenmore 11029842990 WASHER
Kenmore 11029842991 AUTOMATIC WASHER
Kenmore 11029852990 AUTOMATIC WASHER-GALAXY
Kenmore 11029852991 AUTOMATIC WASHER
Kenmore 11029852992 AUTOMATIC WASHER
Kenmore 11029882890 AUTOMATIC WASHER
Kenmore 11029882891 AUTOMATIC WASHER
Kenmore 11029884890 AUTOMATIC WASHER
Kenmore 11029884891 AUTOMATIC WASHER
Kenmore 11029892990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029894990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029962890 AUTOMATIC WASHER
Kenmore 11029962891 AUTOMATIC WASHER
Kenmore 1103348565 GEARCASE
Kenmore 110357116 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357177 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357970 BASKET DRIVE AND BRAKE ASM
Kenmore 110357972 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358364 BASKET DRIVE AND BRAKE ASM
Kenmore 110358365 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358371 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358483 GEARCASE ASM
Kenmore 110358484 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358485 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358487 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358507 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358795 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358841 GEARCASE AND SUPERSTRUCTURE
Kenmore 110359175 BASKET DRIVE & BRAKE ASM
Kenmore 110359178 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110359279 GEARCASE PARTS
Kenmore 110359517 BASKET DRIVE AND BRAKE PARTS
Kenmore 110359699 BASKET DRIVE AND BRAKE PARTS
Kenmore 110360093 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110360867 DOLE MIXING VALVE ASSEMBLY
Kenmore 110360868 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110362101 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362901 GEARCASE ASM
Kenmore 110363000 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363082 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364443 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364444 BASKET DRIVE AND BRAKE PARTS
Kenmore 110364446 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364494 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365011 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365012 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365014 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365359 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365712 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365859 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366660 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366990 BASKET DRIVE & BRAKE ASM
Kenmore 110367551 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110367593 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 1103733107 KENMORE PORTABLE AUTOMATIC WASHER
Kenmore 110389246 GEARCASE PARTS
Briggs & Stratton 110402-0180-E1 ENGINE
Kenmore 11042182200 AUTOMATIC WASHER
Kenmore 11042182201 AUTOMATIC WASHER
Kenmore 11042722200 AUTOMATIC WASHER
Kenmore 11042722201 AUTOMATIC WASHER
Kenmore 11042822200 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11042822201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042822202 AUTOMATIC WASHER HORIZONTAL AXIS
  #2 (permalink)
Old 01-17-2014, 12:18 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Is the motor running when it should be agitating or spinning? Does it drain? Agitator dogs only affect top half of agitator. If motor runs and it drains, then it's likely the coupler that has failed.
Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com
Eric
  #3 (permalink)
Old 01-17-2014, 12:50 PM
Junior Member
Default
You ask whether the motor is running when it should be agitating or spinning and I'm not sure? It does fill properly and it does drain. Washer is not where I am now so I can't check it. It did agitate very, very slowly for about a minute until I changed the cycle, then it wouldn't agitate at all. Does this sound like the coupler?
Bill
  #4 (permalink)
Old 01-17-2014, 02:38 PM
Expert
APP Volunteer
Default
Yes, faulty coupler could cause slow agitation.
Eric
  #5 (permalink)
Old 01-17-2014, 03:07 PM
Junior Member
Default
Thanks Eric. It will probably be a week before I get the part and put it in. I'll let you know the results.
thanks again!
Bill
  #6 (permalink)
Old 03-02-2014, 09:34 AM
Junior Member
Default
It was the motor drive coupling. Appreciate the help.
Bill
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer not agitating VentureRider Washer Repair 2 11-15-2012 03:17 PM
kenmore direct drive washer spin cycle not spining whl66 Washer Repair 2 10-24-2011 08:20 AM
kenmore not agitating bontree Washer Repair 5 06-19-2008 11:30 AM
kenmore not agitating bontree Washer Repair 1 04-11-2008 03:08 PM
kenmore washer not spining out all the time deadeye Washer Repair 4 04-05-2008 06:54 PM
