Discuss
Water Continues To Fill
 in
Washer Repair
We have had a problem of water level overfill [no low or medium ] control for a long time and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water Continues To Fill
  #1 (permalink)
Old 10-17-2009, 07:16 AM
Junior Member
robinlayton is on a distinguished road
Unhappy Water Continues To Fill
Model Number: WLW2500AALWH   Brand: Hotpoint   Age: More than 10 years
We have had a problem of water level overfill [no low or medium ] control for a long time and lived with that. But last night the new fault started, the machine overflowed and the water did not stop until I shut the supplies off. any ideas?I stopped the control knob, and unplugged the electricity to no avail.
Related Models
General Electric WLW2500BAL Washer
General Electric WLW2500BBL Washer
General Electric WLW2500BCL Washer
General Electric WLW2500BNL Washer
General Electric WLW2500RBL Washer
Frigidaire WLW3 Frg(v1) / 27 " Washer
General Electric WLW3000BAL Washer
General Electric WLW3000BBL Washer
General Electric WLW3000BCL Washer
General Electric WLW3000BNL Washer
General Electric WLW3000RBL Washer
General Electric WLW3000SALWH Washer
General Electric WLW3200SALWH Washer
General Electric WLW3200SBLWH Washer
General Electric WLW3300BBL Washer
General Electric WLW3300BCL Washer
General Electric WLW3300BNL Washer
General Electric WLW3300RBL Washer
General Electric WLW3310BBL Washer
General Electric WLW3310BCL Washer
General Electric WLW3310BNL Washer
General Electric WLW3310RBL Washer
General Electric WLW3400SALAD Washer
General Electric WLW3400SALWH Washer
General Electric WLW3400SBLAD Washer
General Electric WLW3400SBLWH Washer
General Electric WLW3440SALAD Washer
General Electric WLW3440SALWH Washer
General Electric WLW3440SBLAD Washer
General Electric WLW3440SBLWH Washer
General Electric WLW3500BAL Washer
General Electric WLW3500BBL Washer
General Electric WLW3500BCL Washer
General Electric WLW3500BNL Washer
General Electric WLW3500RBL Washer
General Electric WLW3505BAL Washer
General Electric WLW3505BBL Washer
General Electric WLW3600BBL Washer
General Electric WLW3600BCL Washer
General Electric WLW3600BNL Washer
General Electric WLW3600SALAD Washer
General Electric WLW3600SALWH Washer
General Electric WLW3600SBLAD Washer
General Electric WLW3600SBLWH Washer
General Electric WLW3610SALWW Washer
General Electric WLW3610SBLWW Washer
General Electric WLW3700BAL Washer
General Electric WLW3700BBL Washer
General Electric WLW3700BCL Washer
General Electric WLW3700BNL Washer
General Electric WLW3700BPL Washer
General Electric WLW3700RBL
General Electric WLW3700RBLWW Washer
General Electric WLW3750BAL Washer
General Electric WLW3750BBL Washer
General Electric WLW3750BNL Washer
General Electric WLW3750RBL Washer
General Electric WLW3760RBLWW Washer
General Electric WLW3800SALAD Washer
General Electric WLW3800SALWH Washer
General Electric WLW3800SBLAD Washer
General Electric WLW3800SBLWH Washer
General Electric WLW3810SALWW Washer
General Electric WLW3810SBLWW Washer
General Electric WLW4700BAL Washer
General Electric WLW4700BBL Washer
General Electric WLW4700BCL Washer
General Electric WLW4700BNL Washer
General Electric WLW5700BAL Washer
General Electric WLW5700BBL Washer
General Electric WLW5700BCL Washer
General Electric WLW5700BNL Washer
General Electric WLW5700RBL Washer
General Electric WLW5900MAL Washer
General Electric WLW5900MNL Washer
Frigidaire WLXG42RED0 Wwh(v1) / Laundry Center
White Westinghouse WLXG42RED1 Laundry Center - W.westinghouse
Frigidaire WLXG42RED3
Frigidaire WLXG42REW0 Wwh(v2) / Laundry Center
White Westinghouse WLXG42REW1 Laundry Center - W.westinghouse
White Westinghouse WLXG42REW2 Laundry Center - West/famsa
White Westinghouse WLXG42REW3 White Westinghouse/laundry Center
White Westinghouse WLXG42REW4 White Westinghouse/laundry Center
White Westinghouse WLXG42REW5 White Westinghouse/laundry Center
General Electric WLXR1020T2WB Washer
General Electric WLXR1020T3WB Washer
General Electric WLXR1020T4WB Washer
General Electric WLXR1020T5WB Washer
General Electric WLXR1020T8WB Washer
General Electric WLXR1020TAWB Washer
 WM0001HTMA Washer
 WM0532HW Washer
 WM0642HW Washer
 WM0742HGA Washer
 WM0742HWA Washer
 WM1333HW Washer
 WM1812CW Washer
 WM1814CW Washer
 WM1815CS Washer
 WM1832CW Washer
 WM2010CW Washer
 WM2016CW Washer
 WM2032HS Washer
 WM2032HW Washer
 WM2042CW Washer
 WM2075CW Washer
 WM2077CW Washer
 WM2101HW Washer
 WM2233HD Washer
 WM2233HS Washer
 WM2233HU Washer
 WM2233HW Washer
 WM2277HB Washer
 WM2277HS Washer
 WM2277HW Washer
Jenn-Air WM227B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM227W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM236B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM236W WALLOVEN- S/C MWAVE ELE
 WM2432HW Washer
  #2 (permalink)
Old 10-17-2009, 08:48 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
here are your parts, could not find exact match to your unit's Model Number so check before ordering anything
Replacement parts for WLW2500AALWH models | AppliancePartsPros.com
Sounds like one of the water valves is shot since killing power to it did not shut it off.
Could be this is related to the water valve but seems that it was too consistent to be a sticking valve, so this would be a long shot.
More likely it is the water level switch or the tubing going from the bottom of the tub to the switch.
Here is a good link with basic washer repair help
http://www.applianceaid.com/washers.html
__________________
  #3 (permalink)
Old 10-17-2009, 01:15 PM
Junior Member
Default
Thank you for your reply. In the time after I posted the question andread some other similar fault I took the water valve off and found the screen was out of place and upon further investigation of the valve found a small stone/mineral deposit under the seat of the cold water inlet valve. that cured the flowing water issue. Also I tested the level switch and determined that it will shut off the water. I have tried an adjustment on it to try to lower the level when it is in the low switch mode ,some suceess, but not all I wanted. thanks again for the info.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
wASHER CONTINUES TO FILL THROUGHOUT CYCLE armyguber Washer Repair 1 08-06-2009 03:26 PM
Water thru the door continues to leak Kluber Refrigerator & Freezer Repair 2 03-07-2009 08:42 PM
bosche dishwasher shu5315uc - water continues to come in even when off grk111 Dishwasher Repair 1 03-06-2009 03:59 AM
water continues to drip into ice maker. silver eagle Refrigerator & Freezer Repair 3 09-22-2008 02:28 PM
continues to fill Vanessa Washer Repair 0 06-23-2008 02:39 PM
