Bearing were bad in my unit, so I replaced bearings, spindle, seals, stator wiring harness and position sensor. The rotor and stator were very dirty with rust. I cleaned them with water and a light brushing and let it dry for at least 4 days. Got the whole unit back together and ran a speed load empty. She seemed a little jerky in the wash and rinse cycle ans never really got into a spin. I ran a second load with towels and now she won't spin in a wash cycle. Did I ruin my stator and if so should the rotor as well or is that good. I got no error codes, she just does not spin. Also, you can hand spin with no problem.
