When i start a cycle the machine locks and start filling water than it spins back and forward for a little bit than the machine stop and beep beep beep with the ADD GARMENT & DOOR LOCK light on. than if i press power to try to start again the machine drain the water than the machine stops and door unlock. during the time the machine try to washer the soap box does not lock so i can open the soap box while machine is going, which NEVER done it before. what could be wrong?????:mad: :mad: :mad: :mad: :mad: Helloitsjen attached the following image(s):
