My washer will not pull hot water. The hot water flow to the machine is fine. How do I know if the solenoid is bad or if it is an electrical switch issue? When I have the machine running on Cold/Cold or Warm/Cold it will operate but only with cold water. When I turn it to Hot/Cold, it completely shuts off.
Groups: Expert
Need the washer model number.
Eric
