jackal6996
#1 Posted : Friday, December 27, 2013 8:30:27 AM(UTC)
jackal6996
ive got a GE GHWP1000M0WW washer. it came with the house that we are renting so idk how old it is, or how long its been used. however, it has a brand new drain hose on it. everytime i run a load of clothes, its fine until the final rinse cycle, then it leaks everywhere. if you look on the backside of the washer you can see that it has been spraying from the connection where this hose goes inside the washer. the drain hose actually goes inside and supposedly is supposed to seal but its defiantly not. im not a major appliance tech by no means but i can usually fix this type of stuff. ill post a video that shows how this hooks up incase someone that might have an answer, doesnt understand what im describing. thank you in advance anyone that can help!
https://www.youtube.com/watch?v=rQFjVEmt04Y
sidfink43
#2 Posted : Saturday, December 28, 2013 4:50:32 PM(UTC)
sidfink43
If you operate it with the front cover off you can see exactly what the problem is and where it is happening. Don't understand why it only does it in the rinse cycle, it may be doing it in the wash cycle too and you just don't notice it.
Anyway run it with front panel off and check to see that the plastic clip that holds the drain hose on is not broken or loose.
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
Dishwasher Leaking Kitchenaid KDTE334DSS0 (Dishwasher Repair)
by Bscott46 10/4/2022 5:16:08 PM(UTC)
Old Maytag 712 Washer Leaking at Injector Valve (Washer Repair)
by ronp99 9/11/2022 1:40:40 PM(UTC)
Maytag top load washer leaking oil from transmission (Washer Repair)
by Rdchapman2 2/27/2022 1:15:02 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4/22/2021 1:13:56 PM(UTC)
Kenmore Washer leaking ONLY Hot water during Fill (Washer Repair)
by colbey 1/11/2020 1:28:22 AM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Whirlpool dishwasher leaking bottom (Dishwasher Repair)
by nkaufman1 5/14/2019 1:50:41 AM(UTC)
Whirlpool washer leaking and won't fill with water (Washer Repair)
by christyhecht 6/16/2018 8:21:00 AM(UTC)
Bosch Dishwasher Leaking into base (Dishwasher Repair)
by Canadianice 4/12/2018 8:18:35 AM(UTC)
Dishwasher leaking underneath [PHOTOS] (Dishwasher Repair)
by jd514 1/6/2018 11:16:52 AM(UTC)
Bosch Nexxt 500 Series Washer leaking (Washer Repair)
by neustkg 9/21/2017 2:46:15 PM(UTC)
Kenmore Series 80 washer leaking water above clutch assembly (Washer Repair)
by hallway 2/5/2017 1:48:24 PM(UTC)
Kitchenaid dishwasher leaking under door (Dishwasher Repair)
by chasethedream 1/1/2017 8:30:50 AM(UTC)
