I recently replaced the drain pump and the shaft and bearing and seal , now everytime I start a wash it goes through the first cycle and then gives an overload code, I can manually advance it to the next cycle and it will run that cycle and give another overload code. any ideas what might be the problem, is it the load sensor?
