randypowers1@aol.com
#1 Posted : Tuesday, December 24, 2013 7:11:24 AM(UTC)
We've had a problem the last couple of weeks with our spin mode not working, but it is only intermittent. It will start working fine again after my wife "works on it" which consists of shaking it and kicking it. I have continuity through the door switch and the mechanical action appears fine. I pulled the motor and the drive coupler looks fine (no erosion on rubber connector and splines all look good on plastic. I put it back together again and turned it on to listen for sounds (i.e. motor running/not running while in spin mode) and it started working fine again. But, as I was testing it, it stopped working again. After reading several blogs I saw some people stating that if they "helped the basket along" then it would spin. The door switch is in the top of the cabinet, so I am not able to leave the lid open while placing a screwdriver in the door switch to watch it with the door open. But I tried to spin the basket to see if I could "help mine along" as others were saying. What I noticed was the basket made a 1/2 to 3/4 turn and then stopped because the break engaged. After I closed the lid it started working again. This leads me to believe that it may be the clutch, but I don't want to start replacing parts by "guessing" until I find the correct one. Does anyone have any suggestions on how to properly diagnose the issue?
fairbank56
#2 Posted : Tuesday, December 24, 2013 8:17:13 AM(UTC)
fairbank56
Groups: Expert
Remove the cabinet and bypass the lid switch. Run in spin mode and observe the clutch hub which is right on top of the gearcase. It should be spinning. Look up above it into the brake hub and you should see the brakes and brake spring spinning as well. If they are and tub is not, then the tub drive block is probably worn. If brakes are not spinning then clutch is slipping either due to worn clutch pads, weak clutch spring or a problem with sticking brakes or brake cam not working.
Lid switch bypass: Lid switch bypassing Whirlpool direct drive washer - YouTube
Cabinet removal: How to Disassemble Whirlpool/Kenmore Direct Drive Washer - YouTube
Eric
