scruffy1138
#1 Posted : Thursday, October 15, 2009 5:14:28 PM(UTC)
scruffy1138
The hot water enters the machine just fine. When you have the temp set to cold, the water starts coming out, but the water shuts off almost immediately. Any suggestions?:confused:
sidfink43
#2 Posted : Friday, October 16, 2009 8:36:44 AM(UTC)
sidfink43
Sounds like the cold water solenoid is failing.
Try this. Reverse the connections on the water valve and set the washer for hot. If the same thing happens, replace the water valve assembly. Here is the part
Part number: AP3175369
kenmore washer problem (Washer Repair)
by paul norton 1/9/2010 8:42:00 AM(UTC)
Kenmore washer problem. Timer? (Washer Repair)
by PC Gator 7/14/2009 7:14:00 AM(UTC)
Sears Kenmore Washer Problem (Washer Repair)
by hocko 12/4/2008 8:35:26 AM(UTC)
