| » Motor kicks off 30-55 seconds into spin |
Model Number: SAV3655AWW Brand: Maytag Age: 5 - 10 years
My Maytag top-load washer burnt a belt. I replaced it, and it worked fine for a few loads and quit. I took the service panel off and turned it on to see water dripping during the spin cycle, so I replaced the triple lip seal and the belt for the second time. Put it back together to find that it runs fine up until the spin cycle. It starts to spin for about 30-55 seconds and kicks off(whether the motor is warm or cold). Please HELP.
If the motor runs but the transmission will not allow the machine to spin then I suspect some water go into the transmission during your leak phase.
If the motor does not run, check the wiring to see if someting is frayed or broken. Good luck, hope this helps.
__________________
I do not think you have an unbalanced switch on this model. You may have a bad connection so I would take off the motor connector and clean it very good with contact cleaner.
Here is the service manual which may help you do some more troubleshooting. http://www.servicematters.com/maytag...s/16022937.pdf
__________________
| Display Modes | |
| Overload Kicks off | allen.robert81 | Refrigerator & Freezer Repair | 0 | 12-29-2009 07:57 AM |
| Washer shuts down 10 seconds after agitate or spin | Chubi2000 | Washer Repair | 1 | 09-20-2009 04:18 PM |
| oven kicks breaker after about 1 hr | wesnan | Oven Repair (including Ranges and Cooktops) | 1 | 09-02-2009 07:41 AM |
| HotPoint washer won't agitate or spin after 2 or 3 seconds | mfleij | Washer Repair | 1 | 12-03-2008 04:32 PM |
| Oven kicks on and off | Helene26 | Oven Repair (including Ranges and Cooktops) | 1 | 07-16-2008 09:49 PM |
