Discuss
Whirlpool Duet Washer won't turn on
 in
Washer Repair
Whirlpool Duet Washer won't turn on Model Number: WFW9200SQ00 Brand: Whirlpool Age: 1 - 5 years I have a Whirlpool
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet Washer won't turn on
  #1 (permalink)
Old 10-15-2009, 04:56 PM
Junior Member
tommyhal is on a distinguished road
Question Whirlpool Duet Washer won't turn on
I have a Whirlpool Model #WFW9200SQ00 and have had it for less than 2 years. I bought it from Lowes and called them to get it repaired and they sent a repairman. Since it was more than 1 yr. the warranty was out. The problem is that it won't turn on when you press the Power button. The repairman checked a few things and called someone at Sears repair center and told him the symptoms and then checked a few more things and they decided the door switch was the problem. The repairman didn't have any parts for the washer even though we had to set up an appointment and gave him the Manufacturer and Model Number and had to wait a week to get him out here. He had a door switch sent out here the following Tuesday by UPS and returned on Thursday to install it and it didn't fix it. He said the CCU was the problem since the door switch didn't fix it and the CCU would cost $400 but he said he'd take the door switch back and send a check for the $100 I had paid for that. I told him I wasn't gonna spend $400 for a CCU as I'd only paid $600 for the washer to start with. I had already seen the CCU at your web site for $268.85 so I bought a CCU from you (Order Date: 10/1/2009 Order Number: 845739) to try to fix the problem and installed it myself. Nothing's changed. I now have $129 in a service call to a repairman that knew no more about it than I do plus $100 for the door switch if he doesn't send the money back and $268.85 plus shipping to you guys and still have the same problem. When you press the Power on button all it does is give 3 quick audible dings. I can lock the controls and unlock them and can get the maintenance codes by pressing the Water Temp button for 3 seconds and release for 3 sec. and press and release for total of three times. All the led's light up even around the knob, then it displays the codes C:00 - Ding - C:00 - Ding - C:00 - Ding - U:01 - Ding - U:00 - Ding - U:00 - Ding - C:00 - Ding - n:00 - Ding - off - Ding - C:00 and stops till you press Pause/Cancel. What else can the problem be?
Thanks for any help you can give.
Tommy Hall
Ads By Google
Related Models
Whirlpool WFW9200SQ00 Automatic Washer
Whirlpool WFW9200SQ01 Automatic Washer
Whirlpool WFW9200SQ02 Automatic Washer
Whirlpool WFW9200SQ10 Automatic Washer
Whirlpool WFW9200SQA10 Automatic Washer
Whirlpool WFW9200SQA11 Automatic Washer
Whirlpool WFW9400SB00 Automatic Washer
Whirlpool WFW9400SB01 Automatic Washer
Whirlpool WFW9400SBA10 Automatic Washer
Whirlpool WFW9400ST00 Automatic Washer
Whirlpool WFW9400ST01 Automatic Washer
Whirlpool WFW9400STA10 Automatic Washer
Whirlpool WFW9400SU00 Automatic Washer
Whirlpool WFW9400SU01 Automatic Washer
Whirlpool WFW9400SW00 Automatic Washer
Whirlpool WFW9400SW01 Automatic Washer
Whirlpool WFW9400SWA10 Automatic Washer
Whirlpool WFW9400SZ00 Automatic Washer
Whirlpool WFW9400SZ01 Automatic Washer
Whirlpool WFW9400SZA10 Automatic Washer
Whirlpool WFW9600TA00 Automatic Washer
Whirlpool WFW9600TB00 Automatic Washer
Whirlpool WFW9600TC00 Automatic Washer
Whirlpool WFW9600TU00 Automatic Washer
Whirlpool WFW9600TW00 Automatic Washer
Whirlpool WFW9600TZ00 Automatic Washer
Amana WG1010.000 Commercial Microwaves
Amana WG1010.010 Commercial Microwaves
Amana WG1010.200 Commercial Microwaves
Amana WG1021.000 Commercial Microwaves
Amana WG1021.200 Commercial Microwaves
Amana WG1065.000 Commercial Microwaves
Amana WG1120.500 Commercial Microwaves
Amana WG1120.600 Commercial Microwaves
Amana WG1121.000 Commercial Microwaves
Amana WG1165.000 Commercial Microwaves
Amana WG1165.700 Commercial Microwaves
Amana WG1166.500 Commercial Microwaves
Jenn-Air WG200 Walloven - Cont Clean Gas
Jenn-Air WG206 Walloven - Cont Clean Gas
Jenn-Air WG24000B Walloven - Std Gas
Jenn-Air WG24000W Walloven - Std Gas
Jenn-Air WG30100B Walloven - S/c Gas
Jenn-Air WG30100W Walloven - S/c Gas
Amana WG445.1 Commercial Microwaves
Amana WG445.2 Commercial Microwaves
Whirlpool WGD5100SQ0 29" Gas Dryer
Whirlpool WGD5200TQ0 29" Gas Dryer
Whirlpool WGD5300SQ0 29"gas Dryer
Whirlpool WGD5300ST0 29"gas Dryer
Whirlpool WGD5310SQ0 29"gas Dryer
Whirlpool WGD5320SQ0 29"gas Dryer
Whirlpool WGD5321SQ0 29"gas Dryer
Whirlpool WGD5500SQ0 29"gas Dryer
Whirlpool WGD5500ST0 29"gas Dryer
Whirlpool WGD5520SQ0 29" Gas Dryer
Whirlpool WGD5521SQ0 29"gas Dryer
Whirlpool WGD5530SQ0 29"gas Dryer
Whirlpool WGD5540SQ0 29"gas Dryer
Whirlpool WGD5540ST0 29"gas Dryer
Whirlpool WGD5550SQ0 29" Gas Dryer
Whirlpool WGD5550ST0 29" Gas Dryer
Whirlpool WGD5560SQ0 29" Gas Dryer
Whirlpool WGD5600SQ0 29" Gas Dryer
Whirlpool WGD5600ST0 29" Gas Dryer
Whirlpool WGD5700SW0 29" Gas Dryer
Whirlpool WGD5790SQ0 29" Gas Dryer
Whirlpool WGD5790ST0 29" Gas Dryer
Whirlpool WGD5800SG0 29"gas Dryer
Whirlpool WGD5800SW0 29"gas Dryer
Whirlpool WGD5810SW0 29"gas Dryer
Whirlpool WGD5820SW0 29"gas Dryer
Whirlpool WGD5821SW0 29"gas Dryer
Whirlpool WGD5830SW0 29"gas Dryer
Whirlpool WGD5840SG0 29"gas Dryer
Whirlpool WGD5840SW0 29"gas Dryer
Whirlpool WGD5850SG0 29"gas Dryer
Whirlpool WGD5850SW0 29"gas Dryer
Whirlpool WGD5856SG0 29"gas Dryer
Whirlpool WGD5860SW0 29"gas Dryer
Whirlpool WGD5900SB0 29" Gas Dryer
Whirlpool WGD5900SW0 29" Gas Dryer
Whirlpool WGD6200SW0 29"gas Dryer
Whirlpool WGD6200SW1 29" Gas Dryer
Whirlpool WGD6400SB0 29"gas Dryer
Whirlpool WGD6400SB1 29"gas Dryer
Whirlpool WGD6400SG0 29"gas Dryer
Whirlpool WGD6400SG1 29"gas Dryer
Whirlpool WGD6400SW0 29"gas Dryer
Whirlpool WGD6400SW1 29"gas Dryer
Whirlpool WGD8300SB0 27" Gas Dryer
Whirlpool WGD8300SB1 27" Gas Dryer
Whirlpool WGD8300SW0 27" Gas Dryer
Whirlpool WGD8300SW1 27" Gas Dryer
Whirlpool WGD8410SW0 27"gas Dryer
Whirlpool WGD8410SW1 27" Gas Dryer
Whirlpool WGD8500SR0 27"gas Dryer
Whirlpool WGD8500SR1 27" Gas Dryer
Whirlpool WGD9200SQ0 Gas Dryer
Whirlpool WGD9400SB0 Gas Dryer
Whirlpool WGD9400ST0 Gas Dryer
Whirlpool WGD9400SU0 Gas Dryer
Whirlpool WGD9400SW0 Gas Dryer
Whirlpool WGD9400SZ0 Gas Dryer
Whirlpool WGD9500TC0 Gas Dryer
Whirlpool WGD9500TU0 Gas Dryer
Whirlpool WGD9500TW0 Gas Dryer
Whirlpool WGD9600SU0 Gas Dryer
Whirlpool WGD9600TA0 27" Gas Dryer
Whirlpool WGD9600TB0 27" Gas Dryer
Whirlpool WGD9600TU0 27" Gas Dryer
Whirlpool WGD9600TW0 27" Gas Dryer
Whirlpool WGD9600TZ0 27" Gas Dryer
Whirlpool WGE30302 30" Electric Range Coil Cooktop
Whirlpool WGE32301 30"electric Range Coil Cooktop E - Z Clean Oven
Whirlpool WGE33001 30" Electric Range E - Z Clean Oven
Whirlpool WGE33301 30" Electric Range
Whirlpool WGE34303 30" Electric Range E - Z Clean Oven
Whirlpool WGE34304 30" Electric Range E - Z Clean Oven
White Westinghouse WGF317ESA White Westinghouse/range
  #2 (permalink)
Old 10-16-2009, 07:32 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Tommy
First of all I have a great deal of sympathy for you. You paid big bucks for what should be an excellent washer, had a problem and when you got a service call from a reputable company you dealt with a service person who could not diagnose the problem and resorted to the process of replacing parts until something fixed it.
Unfortunately Whirlpool has not made these machines easy to diagnose, and has designed them in a way that creates problems like yours in a lot of cases. For even good, experienced techs in some cases the only way to fix problems with the Duet is to replace parts until it works.
Here is what I would do.
1. Check all of the wiring between the CCU and the Door Lock/Catch mechanism. On earlier versions of your machine the current flows from the outlet to the CCU and then to the door switch and then back to the CCU so you could have a problem there. Also check the wiring coming into the CCU from the main power line.
2. If that checks out test for 120v getting to the CCU. If you have it, I would return the CCU to APP and ask for an exchange. These boards are fickle and it is very possible you received a defective board.
3. If these do not fix the problem I would call back Lowes and explain to them that you paid for a service call and repair that did not fix the problem and ask/demand that they send another tech at their expense (for labor) to repair your machine.
Here is a service manual for an earlier version of your machine, which may be of help in testing some components.
https://secured.whirlpool.com/Servic...LE/8178558.pdf
Sorry I cannot be more definitive, but that is the way with microprocessor machines. Good luck.
__________________
  #3 (permalink)
Old 10-16-2009, 04:41 PM
Junior Member
Default
I have checked for 120V through the liine filter and continuity from the door switch to the ccu, I'll check the voltages as well. I appreciate your reply and will probably do as you say.
Don't think I'll buy another microprosser controlled washer. We had a 'bought used' GE we'd had for 25 years till the buttons got so rusty we couldn't push them. Thought the new technology would save money in electricity, didn't know you had to keep paying to fix the machine.
  #4 (permalink)
Old 10-16-2009, 05:15 PM
Senior Expert
APP Volunteer
Default
Ok, good. Let us know how it turns out.
My own opinion is that the technology peaked with the mechanically controlled top loading washer, but the manufacturers had to come up with something new so they went the electronics route. Your experience is proof positive what a huge mistake that was.
__________________
  #5 (permalink)
Old 05-26-2010, 08:08 PM
Junior Member
rodmanlab is on a distinguished road
Default
Tommy Hall
Hi Tommy, I have the same issue with a Kenmore Elite He3t, same codes. I bought the door latch mechanism, installed it and nothing ... Also tried removing the front panel, moving connectors, used an air pump to eliminate dirt, etc... still nothing, I press power and get 3 beeps but no lights ...
Has anyone been able to fix this issue?
  #6 (permalink)
Old 07-13-2010, 06:38 PM
Junior Member
Smile Washer fixed
After contacting lowes back in Sept last year, they told us our warranty had expired and we requested a repairman anyway. They sent us one and he knew less than I did about the problem. Changed the door switch after a week wait to no satisfaction, said he would get us a ccu for $400. I ordered one from AppliancePartsPros and installed it for $182 or so and it made no difference. They allowed a return for full credit. I had another independent repairman check it and he couldn't find the problem either.
As my wife was looking for a coconut cake recipe, she found the Lowes reciept (her filing system) with proof we had purchased the 4 year extended warraty.
She called the number on the warranty and couldn't get anyone to talk to. Press 1 for this 2 for that, etc. I decided to pay a visit to the lowes that had said our warranty was out. The Customer Service lady tried to get through to the warranty department and couldn't over and over until I said that maybe I should have our lawyer handle this. Magically, she pressed the right button and was speaking to a person. Since we now had proof, she got a serviceman to come and check the machine the following Tues. She also gave us a fax number and all the list of requirements to get our money back from the first serviceman. We immediately sent all required info along with a copy of our reciept and this has been 14 days , no reply yet. Anyway the new serviceman from another place than the first diagnosed the problem as a bad Motor Control Board and ordered one and a week and 2 days returned and replaced the board and it now works!!! He diagnosed it by removing the wire connector from the motor control board to the CCU and the washer turned on normal with no error codes. Of course it wouldnt run because of the motor disconnected.
This has been an experience, leaves me wondering about Lowes, The warranty company, the first repairman and the whole thing smells of a rotten, but legal, scam. Just my feelings!! If you do get new appliances, for sure buy the extemded warranty for as long as possible, and for sure don't misplace the reciept and warranty info, because they are counting on that!!! Good luck to all who have an appliance problem. On another note, we have a Sears refridgerator that quit and had the reciept at hand and they snapped to and repaired the thing pronto, well two weeks because of waiting to get parts.
  #7 (permalink)
Old 07-14-2010, 04:33 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Good info here will keep it for future reference. So apparently the failed motor control board sent msgs. to the ccu and it shut the unit down. Unplugging it caused a loss of the error msgs.
There is a very good repair guide at web site Whirlpool Duet Front-Loading Washer Not Running Repair Guide
This guide shows a good diagnostic at the ccu connector for the door switch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stupid Whirlpool Duet Wont Turn On sarawins Washer Repair 9 05-02-2013 06:12 PM
Whirlpool Duet Washer won't turn on tommyhal Dishwasher Repair 9 08-04-2010 05:04 PM
Whirlpool Duet Dryer clicks, but does not turn KPfromIowa Dryer Repair 6 06-27-2010 06:01 PM
Whirlpool Duet Washer tomanton Washer Repair 0 04-01-2009 02:20 PM
