Hello,
Would appreciate an advice about my washer. It will work fine through the all cycles, but when it comes to SPIN cycle it will not spin. I have checked if an article of clothing has stuck between the drum and the body of the washer - negative. Belt is spinning fine and there is no burning smell.
Thank you for any advice.
