Having problems with my Maytag Washer, SAV2655AWW. It stopped in the middle of a load and I haven't been able to get it to run since. When I set the timer and pull the knob, all I get is a clicking noise from the timer, (sounds like an old school egg timer). I have looked at the drive belt and it is tight and in good order, the lid switch seems to work because when I lift the lid the clicking from the timer stops. Do I have a bad timer or is there another problem?
