My washer is leaking from the front and just by leaning it back and looking underneath, it appears to be leaking from the pump. It is stained at the bottom of the pump where water has been constantly dripping. I don't think it is the hoses just the pump. Is this possible, because the pump seems to be just one piece?
I'm not a pro but If your leaning it back maybe that's just where the water happens to be coming out of, my washer has a little panel in the back that comes off so you can see the pump in action, maybe yours does to. I have a pump problem right now, I would guess if something is wrong with your washer the pump or hose would be the easiest and least expensive then that tub area
THIS FORUM IS DEAD!!!!!!! |
