Hello, I've been having an issue with my washer overflowing on the first and second fill cycles. this is an intermittent problem. currently I am having no luck with fiddling with the load size dial (pressure switch). I have blown air through the pressure hose to the switch while filling with success. After doing so the washer worked normally through a few loads, then went back to periodically spewing gallons of water onto my floor. we do wash diapers in the washer. before I buy a replacement pressure switch I'm wondering if there is a way to access the ?port? on the side of the basin to verify there's no clogs preventing the switch to register pressure. the hose appears to be intact throughout. any help is greatly appreciated!
Groups: Expert
You need to know how to remove the front panel of the washer?
Eric
Originally Posted by: fairbank56 You need to know how to remove the front panel of the washer? Eric thanks eric - yes I can access the inside of the panel. my question is simply whether an intermittently working pressure switch points to a clog in the line or a bad switch? replacing the switch looks easy enough - cleaning out the area where the hose connects to the basin looks hard to reach.
Groups: Expert
Well, if you take the front panel off, the tub air dome is right there where you can get to it, that's why I asked if you need instructions on removing the front panel. Just pull the hose from the air dome and check that end of the hose for gunk and then you can flush out the air dome using hot water in a turkey baster or other suitable tool for getting hot water into it under pressure. A bad switch, clogged air dome/hose, holes/kinks/splits in the hose can all cause the problem you are having as well as a sticking water inlet valve. If turning the washer off stops the water flow, then the inlet valve is ok.
Eric
Originally Posted by: fairbank56 Well, if you take the front panel off, the tub air dome is right there where you can get to it, that's why I asked if you need instructions on removing the front panel. Just pull the hose from the air dome and check that end of the hose for gunk and then you can flush out the air dome using hot water in a turkey baster or other suitable tool for getting hot water into it under pressure. A bad switch, clogged air dome/hose, holes/kinks/splits in the hose can all cause the problem you are having as well as a sticking water inlet valve. If turning the washer off stops the water flow, then the inlet valve is ok. Eric oops, sorry about that, thought you meant the instrument panel. yes actually, instructions for the front panel would be mighty handy, thank you. i'll go about flushing the air dome tonight. glad I finally have a name for it! the inlet valve is fine. thanks again
Groups: Expert
Remove the top two screws from the transition panel between washer and dryer, tilt panel down and lift out. Remove two screws behind top panel, pull top panel forward to disengage locks, disconnect lid switch harness and remove top panel. Remove the two screws from inside the top of the front panel, lift up on panel to release bottom catches and remove panel.
Eric
Originally Posted by: fairbank56 Remove the top two screws from the transition panel between washer and dryer, tilt panel down and lift out. Remove two screws behind top panel, pull top panel forward to disengage locks, disconnect lid switch harness and remove top panel. Remove the two screws from inside the top of the front panel, lift up on panel to release bottom catches and remove panel. Eric ok I flushed about a pint of h2o through the air dome, as well as blew air. at this point a clog seems unlikely. I ran a cycle with the panel off and watched the dome fill a bit into the hose, so it looks like its building pressure fine. On subsequent washes I watched the basin fill almost to the top, at which point I turned it off, dicked around with the load size knob, and turned it back on. that always got the agitation started. each time the rinse cycle seemed to work to spec based on the setting of the pressure switch. at this point I'm reasonably sure its the switch that's the problem. thoughts? thanks for your time and attention.
Groups: Expert
I agree, looks like a faulty pressure switch.
Eric
