Discuss
Top Agitator Does Not Engage
 in
Washer Repair
Actually A Roper Brand But Believe It The Same. Serial # Cg1321031, How Do You Take Agitator Apart? Do I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Top Agitator Does Not Engage
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-14-2009, 02:50 PM
Junior Member
mark sydor is on a distinguished road
Default Top Agitator Does Not Engage
Model Number: RAX6144EW1   Brand: Whirlpool   Age: More than 10 years
Actually A Roper Brand But Believe It The Same. Serial # Cg1321031, How Do You Take Agitator Apart? Do I Need The Item #11 (kit) In The Parts Drawing , Or Somthing Else? Item #3, In Drawing, Spins Free When Unit Is Off Or On, Maybe The Dogs Are Worn Out?
Related Models
Whirlpool RAX6144EW1
Roper RAX7244EN0 WASHER
Roper RAX7244EN1 WASHER
Roper RAX7244EQ0 WASHER
Roper RAX7244EQ1 WASHER
Roper RAX7244EW0 WASHER
Roper RAX7244EW1 WASHER
Roper RAX7244JQ0 WASHER
Roper RAX7244KQ0 WASHER
Roper RAX7244KQ1 AUTOMATIC WASHER
Roper RAX7244KQ2 AUTOMATIC WASHER
Roper RAX7244PQ0 AUTOMATIC WASHER
Roper RAX7244PQ1 AUTOMATIC WASHER
Whirlpool RAX7245AG0
Whirlpool RAX7245AL0
Roper RAX7245AW0 Washers*
Roper RAX7245BL1 AUTOMATIC WASHER
Roper RAX7245BQ1 AUTOMATIC WASHER
Roper RAX7245BW0 DIRECT-DRIVE AUTOMATIC WASHER
Roper RAX7245BW1 AUTOMATIC WASHER
Roper RAX7245JQ0 WASHER
Roper RAX7245KQ0 WASHER
Roper RAX7245KQ1 AUTOMATIC WASHER
Whirlpool RB1000XKW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XKW1 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XKW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYN2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1005XYN3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYN5 24" ELECTRIC OVEN
Whirlpool RB1005XYW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYW2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1005XYW3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYW5 24" ELECTRIC OVEN
Whirlpool RB100PXK-0 24" ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXK0
Whirlpool RB100PXK1 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXK2 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV0 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV2 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV3 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB0 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB100PXYB3 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB5 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1200XKW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XKW1 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XKW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XVW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XVW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXK1 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXK2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV0 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV1 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV3 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXYB0 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXYB2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB120PXYB3 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB120PXYB5 24" ELECTRIC OVEN
Whirlpool RB1300XKW1 COOKTOP
Frigidaire RB130FA0 Frg(v5) / Electric Range
Frigidaire RB130FF0 Frg(v4) / Electric Range
Frigidaire RB130FH0 Frg(v6) / Electric Range
Frigidaire RB130FL0 Frg(v3) / Electric Range
Frigidaire RB130FM0 Frg(v2) / Electric Range
Frigidaire RB130FW0 Frg(v1) / Electric Range
Whirlpool RB130PXK0 BUILT IN DOUBLE OVEN
Whirlpool RB130PXK1 BUILT IN DOUBLE OVEN
Whirlpool RB130PXK2 BUILT IN DOUBLE OVEN
Whirlpool RB130PXK3 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV0 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV1 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV3 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV4 BUILT IN DOUBLE OVEN
Frigidaire RB131CA0 Frg(v1) / Electric Cooktop
Frigidaire RB131CA1 Frg(v1) / Built - in Electric Cooktop
Frigidaire RB131CF0 Frg(v2) / Electric Cooktop
Frigidaire RB131CF1 Frg(v2) / Built - in Electric Cooktop
Frigidaire RB131CH0 Frg(v3) / Electric Cooktop
Frigidaire RB131CH1 Frg(v3) / Built - in Electric Cooktop
Frigidaire RB131CL0 Frg(v4) / Electric Cooktop
Frigidaire RB131CL1 Frg(v4) / Built - in Electric Cooktop
Frigidaire RB131CM0 Frg(v5) / Electric Cooktop
Frigidaire RB131CM1 Frg(v5) / Built - in Electric Cooktop
Frigidaire RB131CW0 Frg(v6) / Electric Cooktop
Frigidaire RB131CW1 Frg(v6) / Built - in Electric Cooktop
Frigidaire RB131NL1 Frg(v2) / Electric Range
Frigidaire RB131NL2 Frg(v3) / Electric Cooktop Range
Frigidaire RB131NL3 Frg(v6) / Electric Cooktop Range
Frigidaire RB131NM1 Frg(v3) / Electric Range
Frigidaire RB131NM3 Frg(v4) / Electric Cooktop Range
Frigidaire RB131NW1 Frg(v1) / Electric Range
Frigidaire RB131NW2 Frg(v2) / Electric Cooktop Range
Frigidaire RB131NW3 Frg(v5) / Electric Cooktop Range
Frigidaire RB136CDB0 Frg(v1) / Electric Range
Frigidaire RB136CL1 Frg(v1) / Electric Cooktop
Frigidaire RB136CL2 Frg(v1) / Electric Cooktop
Magic Chef RB150ALM REF - TOP MOUNT
Magic Chef RB150ALV REF - TOP MOUNT
Magic Chef RB150AM REF - TOP MOUNT
Magic Chef RB150AV REF - TOP MOUNT
Magic Chef RB150PA REF - TOP MOUNT
Magic Chef RB150PLA REF - TOP MOUNT
Magic Chef RB150PLW REF - TOP MOUNT
Magic Chef RB150PW REF - TOP MOUNT
Magic Chef RB150RA REF - TOP MOUNT
Magic Chef RB150RLA REF - TOP MOUNT
Magic Chef RB150RLW REF - TOP MOUNT
Magic Chef RB150RW REF - TOP MOUNT
  #2 (permalink)
Old 10-15-2009, 01:41 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Sounds like you need an agitator kit, this part here
Part number: AP3138838
Take off the top caps on your agitator and you will see either a square hold or a bolt. If it is a bolt, unscrew it, and if it is the square hole, insert a device that will enable you to unscrew it.
The top of the agitator will come off and you can replace the dogs. Click on your model number if you need to see the diagram and part.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Washer won't engage belt mljac Washer Repair 0 02-24-2009 07:54 PM
Rinse Cycle Will Not Engage abtcs2677 Washer Repair 3 02-24-2009 03:52 AM
Hotpoint dryer that will not engage the drum? REdted Dryer Repair 0 12-29-2008 08:06 AM
Basket will not engage on spin cycle DJoseph Washer Repair 0 09-26-2008 09:35 PM
window A/C Compressor won't engage all the time. aqpmedic Heating, Ventilation, and Air Conditioning (HVAC) 4 07-30-2008 08:24 PM
